Vector space dimension question
The discussion focuses on proving that the space of 2×2 real matrices is a vector space of dimension 4 over R. Participants suggest finding an isomorphism from the space of 2×2 matrices to R^4 using a linear transformation T that maps a matrix [a,b;c,d] to the vector (a,b,c,d). To establish that T is an isomorphism, it is necessary to show that it is a linear transformation and that its kernel is zero, indicating that the image of T spans R^4. A basis for the space of 2×2 matrices is identified, consisting of four linearly independent matrices, confirming that the dimension is indeed 4. The conclusion emphasizes that every 2×2 matrix can be expressed as a linear combination of these basis matrices.
P-Jay1
Prove that the space of 2×2 real matrices forms a vector space of dimension 4 over
R. [12]
Im unsure, anyone any idea?
If I understood right, we have to find an isomorphism from M^{R}_{2x2} to R^4.
In other word, we need to find a linear transformation, T:M^{R}_{2x2} \rightarrow R^4 that ker(T)=0.
HINT: look at T[a,b;c,d]=(a,b,c,d)
What's your book's definition of "dimension 4". I use the definition that says that a vector space is 4-dimensional if it contains a linearly independent set with 4 members, but no linearly independent set with 5 members. So to solve your problem, I would find a set of 4 linearly independent matrices and prove that every matrix is a linear combination of those four.
So what does ker(T) stand for? I am still really clueless. So do I find an isomorphism from T[a,b;c,d] to (a,b,c,d)?
ker T is the set of all x such that Tx=0. Finding that isomorphism is one way to do it, but not the only one. Edit: Wait, you said "from T[a,b;c,d]". I don't know what you mean by that. I meant that one way to solve the problem is to find an isomorphism from the set of 2×2 matrices to ℝ4.
I guess I wasn't much clear. What I meant is that T takes a matrix [a,b;c,d] and gives a vector (a,b,c,d). Actually, I think that this is what he has meant.
A = (a b c d)
A = a (1 0 0 0) + b (0 1 0 0) + c (0 0 1 0) + d (0 0 0 1)
Please excuse my lack of ability to lay this out correctly but each of these in brackets have 2 rows and 2 columns i.e 2 x 2. not 1 x4
a,b... Eℝ is a vector space over ℝ
Is this the correct approach?
it seems like you know the answer but don't know how to do this.
so first of all, let's state that "in order to prove that the space of 2×2 real matrices forms a vector space of dimension 4 over R. we will define an isomorphism from 2x2 real matrices space to R4". Later, we will say. "lets take a look at the following transformation T:M2x2->R4, T([a,b;c,d])=(a,b,c,d)"
now, what is left to do is to show that it is linear transformation and that it is a isomorphism.
regarding the linear transformation, it's not a big deal. i am sure you can handle it by yourself.
to show that T is isomorphism we need to prove that T is a linear transformation and ker(T)=0 or im(T)=4.
to do that - we need to know first what im(T) is equal. if we take a base of one space and we transform it using T we will get the base of the other space we are transforming to. so let's take the standard base of M_2x2(R). { [1,0;0,0], [0,1;0,0], [0,0;1,0], [0,0;0,1]}. from what we have defined before:
T([1,0;0,0])=(1,0,0,0); T([0,1;0,0])=(0,1,0,0) ... T([0,0;0,1])=(0,0,0,1).
in other terms, imT(M_2x2(R) ) = sp{(1,0,0,0),...,(0,0,0,1)}, but the set {(1,0,0,0)...(0,0,0,1)} is the standard base of R4 thus dim(imT)=4. so in conclusion, T is an isomorphism, and we proved what we have asked for.
Any 2 by 2 matrix is of the form
\begin{bmatrix}a & b \\ c & d \end{bmatrix}= a\begin{bmatrix}1 & 0 \\ 0 & 0 \end{bmatrix}+ b\begin{bmatrix}0 & 1 \\ 0 & 0 \end{bmatrix}+ c\begin{bmatrix}0 & 0 \\ 1 & 0 \end{bmatrix}+ d\begin{bmatrix}0 & 0 \\ 0 & 1 \end{bmatrix}
The most "basic" definition of "dimension" is that it is the number of vectors in any space. It is easy to see that these four matrices are a basis.
Or, if as Boaz does, you wish to find an isomorphism,
f\left(\begin{bmatrix}a & b \\ c & d\end{bmatrix}\right)= (a, b, c, d)
works nicely.
  • · Replies 58 ·
  • · Replies 17 ·
  • · Replies 23 ·
