Representing Vectors in Newton's Notation: How to Use Overdot and Arrow Symbols?
In Newton's notation, the representation of vectors can involve both overdot and arrow symbols, with the common convention being to use the format ##\dot{\vec{x}}##. While some may question whether to place the overdot above the arrow or vice versa, the first option is generally preferred. It is noted that dot notation is typically associated with derivatives of scalar quantities, but it can also apply to vectors without issue. Ultimately, the choice of notation often depends on the conventions established in specific texts or papers. Understanding these conventions is essential for clear communication in physics and mathematics.
sams
A very simple question. How do we represent a vector with Newton's notation (writing the arrow symbol with the overdot notation)? Can we write them both above each other. First, the overdot notation and then the arrow symbol?
Thank you a lot for your help...
you mean which is correct ##\dot{\vec{x}}## or ##\vec{\dot{x}}##? I think the first one... But it is a matter of convention, usually in the book or the paper there will be some footnote or appendix that explains the conventions in symbols.
Anyway, I think dot notation for derivatives is used usually with scalar quantities, not with vector ones.
The typical notation would be ##\dot{\vec x}##. There is nothing particular with using the dot notation for vectors vs scalars.
Thank you sirs for your help...
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 25 ·
  • · Replies 27 ·
