How Do You Calculate the Velocity of a Point on a Rotating Disc?
To calculate the velocity of a point on a rotating disc at 800 rpm, first convert the rotation speed to revolutions per second (40/3 rps). The period T is then determined as 3/40 seconds. The velocity v can be calculated using the formula v = (2πr) / T, resulting in v = (80πr) / 3 m/sec. It's crucial to maintain the "seconds" unit throughout the calculation to ensure the final result is in distance/time. This method confirms the correct approach to finding the velocity of a point on the rotating disc.
JJK1503
Find the velocity v of a general point on a plate rotating at 800 rpm which is r meters from the center.
This is literally a copy and paste job.
period = T = 1 / f ; f = frequency
This is what I did please tell me if it is correct
800 rpm = 40 / 3 rps = f
T = 1 / f = 3 / 40
v = distance / time = (2 pi r) / (3 / 40) = (80 pi r) / 3
That is correct.
You could also have seen that 40/3 rps can be directly translated into a speed by replacing the r in rps with the distance covered in 1 revolution (2 pi r).
That would give you the same result ##\frac{80 \pi r}{ 3}##m/sec.
Yes, that works. You need to carry the "seconds" unit through to the end though. The period T has seconds as its unit.
Otherwise you'll end up with a "velocity" with units of distance rather than distance/time.
RUber said:
That is correct.
Awesome! Thank you.
Ohh... I see. Thank you
  • · Replies 32 ·
  • · Replies 17 ·
