Why Does a Satellite's Speed Increase as It Moves Closer to Earth?
  • Thread starter Thread starter sheevz
    Speed
The speed of a satellite in orbit increases as it moves closer to Earth due to the principles of gravitational force and energy dynamics. Using the formula V = √(GM/r), where G is the gravitational constant and M is the mass of Earth, it is established that a decrease in orbital radius results in an increase in orbital speed. This phenomenon occurs because gravitational force is an inverse-square force, necessitating higher speeds for stable orbits closer to the center of attraction. Additionally, the concept of negative mechanical energy indicates that as potential energy decreases, kinetic energy increases, leading to higher speeds in lower orbits.
  • Understanding of gravitational force and its inverse-square law
  • Familiarity with orbital mechanics and centripetal force
  • Knowledge of kinetic and potential energy concepts
  • Basic proficiency in algebra and physics equations
  • Explore the derivation of the virial theorem in gravitational systems
  • Learn about gravitational potential energy and its implications in orbital mechanics
  • Investigate the concept of "heating by gravitational collapse" in astrophysics
  • Study the effects of varying orbital radii on satellite speed and stability
Astronomy students, physicists, aerospace engineers, and anyone interested in the dynamics of satellite motion and gravitational interactions.
sheevz
find the speed of a satillite in orbit 1000km above the Earth's surface.
mass of Earth 5.98*10^24kg
mass of satellite = 50.0kg
radius of earth=6.38*10^6m
so i used V= square root of G*mass of earth/r
V= square root of (6.673*10^-11)(5.98*10^24)/7.38*10^6)
note***7.38*10^6 is the radius of the Earth plus the 1000km above the Earth's surface***
i get V= 7.353*10^3m/s
ok now my real question is if i DECREASE the distance above the Earth let's say by 100km i know that the velocity or my speed will increase but can someone tell me why this increases? i understand how in figuring out with numbers but why does the speed increase as the distance gets closer to the center?
You can look at this in terms of force or in terms of energy.
In terms of centripetal force, gravity supplies this force, so we have
m·(v^2)/r = GmM/(r^2) .
When you solve this for the speed along the (circular) orbit, we find
(v^2) = GM/r .
Because gravity is an inverse-square force, a stable orbit requires a higher speed along an orbit closer to the center of attraction. (This works the same way for electrostatic forces.)
In terms of energy, a bound orbit has negative mechanical energy. Since the gravitational force is attractive, the potential energy in a system is always negative (zero potential being assigned to infinite separation between masses in a system). As total mechanical energy is kinetic plus potential energy, and kinetic energy is always positive, a closer orbit has a more negative potential energy and a more negative total mechanical energy. The virial theorem (you can look up a proof) tells us that for gravity, U = -2K . So as the potential and total mechanical energy become more negative, the kinetic energy becomes more positive.
This increase in kinetic energy leads to what is called a "gravithermal catastrophe". In the limit as the radius of the orbit shrinks to zero, the kinetic energy would run away to infinity. In reality, this doesn't happen, since material particles would ultimately get in each other's way. What this does make possible, though, is "heating by gravitational collapse", which is basically why we have stars...
  • · Replies 21 ·
