Velocity Profile Analysis for Force Balance Equation in Fluid Dynamics
38 replies · 4K views
hotjohn
if we divide the force balance equation by 2pi r dx , we would get
(P_(x+ Δx) ) - (P_x) + ( τ_(x + Δx) ) - τ_(x) = 0 , am i right ? why the notes give different eqaution ?
The analysis in the book looks correct to me. Why do you have the τ's evaluated at x and x + Δx? They are shear stresses on the shell element being analyzed at r and r + Δr.
Can you explain how do you get the same formula derivation with the book? I can't understand it...
There are four horizontal forces acting on the element: two opposing but slightly different pressures acting on the sides, and two opposing but slightly different shear forces acting above and below.
The shear force varies with radius, not as a function of x.
can you expalin why the area of τ is 2 pi r dx ? why not 2 pi rdr?
The element is a ring, radius r, rectangular cross section dxdr. The shear forces act on the surfaces parallel to the pipe. These are bands of width dx. The radius of one is r, the other r+dr. So the surface areas are 2 pi r dx and 2 pi (r+dr)dx.
The surfaces that the ##\tau##'s are acting upon are cylindrical. In terms of R and L, what is the curved surface area of a cylinder?
ok , I understand that the shear stress act on the area = 2 pi r dx , can you explain why the pressure act on the area = 2 pi r dr ?
It acts on the end of the shell, with cross sectional area ##\Delta A = \pi (r+\Delta r)^2-\pi r^2=\pi[(r+\Delta r)^2-r^2)=\pi \Delta r(2r+\Delta r)##. In the limit of small ##\Delta r## compared to r, this becomes ##dA=2\pi r dr##.
in the pipe , why not the r = constant, which is r ? why there is delta r ?
why the shear stress not act on a round cross sectional area ? if it act on the round surface area , the area would be 2 pi r dr , am I right ? the dx is for the rectangular cross sectional area , right ?
r is not the pipe radius. r is the radial coordinate measured from the centerline.
The shear stress is acting on surfaces of constant r and is oriented in the x direction. At radial coordinate r, the area of the free body surface that the shear stress acts upon is ##2\pi r dx##. There is no shear stress acting on the end surfaces of the free body. (Only the pressure acts on the end surfaces).
Chet
Chet
do u mean the shear stress act on the cylindrical volume , but not on the end surface of free body ? since 2pi r dx = cylindrical volume ? 2 pi dx is the circumference , times dx , we would get the volume
Cylindrical surface, not volume. And, yes, it doesn't act horizontally on the end surface of the free body.
This is surface area, not volume.
2 pi r is the circumference, times dx, we get the surface area.
Shear force is like friction.
Imagine pulling on a long tight sock. The radius of your leg is r, the thickness of the sock dr, its length x. The normal pressure is P.
The surface area of the sock contacting your leg is ##2\pi r x##, so the frictional force is ##2\pi r x P \mu##. No dr in there anywhere.
why 2 pi r dx is sufrace area ?
when we take thickness multiply by the 2 pi r , we eou;ld get vplume , right ? can you explain further ? or can you attach a diagram ?
haruspex said:
That's only multiplying two distances, so it can give area but not a volume.
Look at http://keisan.casio.com/exec/system/1340330749.
For the shear force, we are interested in the cylindrical surfaces. In the image, these have areas ##2\pi r_1 h## and ##2\pi r_2 h##.
do u mean the shear stress act on the pipe inward and outward of tha paper? while the pressure act on the surface area of pipe from the right adn the left ?
No, all four forces act horizontally right and left.
##2\pi r_1 h## is the lateral area right ? shear force must act perpendicular to the lateral area , right ? so it the shear force should be inward and outward of the book , right ?
No, shear force acts along the surface. That's why it is called shear force, not normal force.
Chestermiller said:
can someone try to explain why the shear stress force at down and above in diagram 8-11 is opposite in direction ? why in diagram 8-12 , they are in the same direction ?
8-11 considers two radii r and r+Δr on the same side of the central axis. Because of the velocity (fastest in the cental axis) the relative velocities create opposite drags either side of the elemenrt
8-12 considers an entire disc of radius r, so the opposite sidea of it are on opposite sides of the central axis. The same velocity profile leads to drag in the same direction on opposite sides.
See Chet's diagram above. The two τ(r+Δr) are in the same direction, but in opposite direction to τ(r).
for 8-11, since the velocity profile is drawn from left to right ( same direction) for both r and r+Δr ,m why it will create opposite drags?
one more question , why the τ is given by - μ / ( du /dr ) ? why y = R -r ? where is r measured from ? where is y measured from ? it's not shown in the diagram
Δ
The velocity is greatest at the central axis. The annulus just inside radius r is moving faster than that between r and r+Δr, so drags it in the forward direction. The annulus just beyond r+Δr Is moving more slowly than that between r and r+Δr, so drags it in the backward direction.
haruspex said:
Δ
i still don't understand why the resultant drag is in opposite direction , could you explain further?
