Velocity Related Problem -- A body is thrown upward....
  • Thread starter Thread starter Shahab Mirza
    Body Velocity
The problem involves a body thrown upward, remaining in the air for a total of 10 seconds. Participants are discussing the initial velocity required for this motion, with some confusion regarding the calculations and assumptions made about the motion's characteristics.
  • Mixed
  • Some participants attempt to analyze the motion in two parts: the ascent and descent, suggesting that the time to reach the maximum height is half of the total time. Others question the validity of assuming the final velocity at the peak is zero, arguing that the motion can be considered as a single parabolic trajectory.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants provide guidance on how to approach the calculations, while others express uncertainty about the assumptions being made regarding the motion and the use of equations.
There is a noted confusion regarding the interpretation of the total time in the air and the implications for the initial velocity calculation. Participants are also discussing the nature of projectile motion and the appropriate equations to apply.
Shahab Mirza
A body is thrown upward and remains in air for 10 seconds , the initial velocity at which it was thrown in is?
g = -10 , t = 10 s , vf = 0 , vi = ?
Vf = vi + gt
0=vi + (-10) (10)
Vi = 100
but its answer is not 100 its answer is 50 help me please , where I did a mistake ? Thanks[/B]
Here u got to consider the motion in two parts,
1. From down to up and
2. Up to down
From down to up we have u=u, v=0 (velocity at top is 0, it is momentarily at rest at that point), (Here)t=10/2=5s, g=-10m/s(as direction of u is opposite to acc or force of gravitation) so we have:
v=u+at
0=u-10*5
u=50
Also when you will check motion from up to down you will get the same 'u', it signifies that in a projectile motion velocity at two points lying on the same horizontal line in up and down motion will have the same velocity.
Or use formula of Projectile motion T=2usinx/t, here x=90 degree so 10=2u/10 or u=50m/s
2. Up to down
v=u+at
0=u-10*5
u=50
Thanks a lot sir .
Oh so it means that T =10 seconds was the time ball was in air it means that it was time taken from throwing ball upward and then catching it in hand hence where the ball momentarily stops , the time till then is 5 seconds .
It means I didn't understood question correctly , the equation I used was fine , Thanks a lot
This is not true, it is perfectly fine to consider the motion as one single parabola.
Where did you take vf = 0 from? This would imply that the body hits the floor at zero velocity.
vf is the velocity at the max height of the parabolic path bro.
Vf is velocity at max height where ball stops for a while
It does not need to be and it was not clear in the OP. The natural thing to do in this problem would be to consider the full parabolic motion from the initial time until the time the ball hits the ground with the same velocity (but with opposite sign) as the initial one. Your assertion that you need to consider it as two separate motions is simply not true.
The ball never stops "for a while". It will only be at rest momentarily. If you want to do it this way, then you need to consider that it will take half the time to reach the top as already pointed out. The alternative is to consider that on the way down, the body will hit the ground with the same speed as it was thrown, but with the velocity directed in the opposite direction, i.e., vf = -vi. This will take the full 10 seconds.
Orodruin said:
It does not need to be and it was not clear in the OP. The natural thing to do in this problem would be to consider the full parabolic motion from the initial time until the time the ball hits the ground with the same velocity (but with opposite sign) as the initial one. Your assertion that you need to consider it as two separate motions is simply not true.The ball never stops "for a while". It will only be at rest momentarily. If you want to do it this way, then you need to consider that it will take half the time to reach the top as already pointed out. The alternative is to consider that on the way down, the body will hit the ground with the same speed as it was thrown, but with the velocity directed in the opposite direction, i.e., vf = -vi. This will take the full 10 seconds.
It means that I should apply time equation of projectile . It will be correct option ?
2. Up to down
v=u+at
0=u-10*5
u=50
Okay let me correct it a bit...Projectile is motion in 2D, you can divide this motion along separate x and y axis, and apply equations of constant acc. accordingly along both directions.
If you have any problem getting it, go through the derivation of projectile formulas.
v=u+at
0=u-10*5
u=50
So either you take a single parabolic path or take motion along x and y axis, its one and the same thing.
Yes thanks a lot
  • · Replies 17 ·
  • · Replies 34 ·
