Vena contracta in orifice plates
  • Thread starter Thread starter DaiG
    Orifice Plates
The discussion focuses on determining the diameter of the vena contracta in gas and vapor flows through orifice plates. The coefficient of contraction (Cc) is defined as the ratio of the area of the vena contracta to the area of the orifice, typically approximated at 0.62 for sharp edge orifices. However, adjustments may be necessary to account for fluid compressibility, using the expansion factor (Y) in calculations. The user expresses concerns about the reliability of approximating Cc, as small variations in process variables can significantly impact noise calculations in orifice plates.
  • Understanding of orifice plate flow dynamics
  • Familiarity with the coefficient of contraction (Cc)
  • Knowledge of fluid compressibility effects
  • Basic principles of acoustic noise measurement in fluid systems
  • Research methods for calculating the vena contracta diameter in orifice plates
  • Explore the impact of compressibility on flow measurements in gas and vapor systems
  • Investigate advanced techniques for noise prediction in fluid systems
  • Learn about the expansion factor (Y) and its application in flow calculations
Engineers, fluid dynamics specialists, and acoustic analysts involved in the design and analysis of orifice plates and flow measurement systems.
DaiG
Hi, does anybody know how to find the diameter of the vena contracta in gas/vapour flows in orifice plates?
This is given by the coefficient of contraction Cc = Area vena contracta / Area Orifice. The value is usually about 0.62 for a sharp edge orifice. These results may need correction for the compressibility of the fluid. To a first approximation, multiply Cc X Y where Y is the expansion factor.
Yea, I am aware of this method but concern is with the coefficeint Cc. Usually an approximation would be good enough and 0.61 to 0.64 usually does the trick. My issue is I am trying to develop a method for calculating a value of noise in orifice plates. approximating Cc isn't a reliable method for me because my final decibel value is thrown substantially if certain process variable differ by 0.01 decimal places and the vena contracta velocity and area are troubled areas for me. Thanks anyway though.
  • · Replies 45 ·
