Calculating Water Flow Using a Venturi Meter
  • Thread starter Thread starter HethensEnd25
    Meter Venturi
A venturi meter with a 4-inch to 1-inch diameter measures water flow, with a mercury manometer showing a 1-inch deflection. The discussion highlights the use of the Bernoulli Equation and the continuity equation to calculate the discharge through the larger pipe. The pressure differential indicated by the mercury deflection is crucial for solving the problem. The participant expresses initial confusion about the relevance of the deflection but later confirms that it is essential for determining flow rate. The problem has been solved, and the participant plans to share the final answer after verification.
HethensEnd25
A 4 inch to 1 inch diameter venturi meter is used to measure water flow and it
has a mercury manometer deflection of 1 inch. What is the discharge
through the four inch diameter pipe?
Bernoulli Equation, manometer formula
Thus far my attempt at a solution is using the Reynolds Transport Theorem. I know that for a steady flow process that there will be no change in volume for the control volume. Thus that term will be zero. So now I am left with
∫ρV*dA
I have two diameters given and I know that it is a in-compressible fluid. So my flow in must equal my flow out. I am confused however upon the given information regarding the mercury deflection. Am I to use that deflection to give myself a pressure? Or is that a piece of information that is nonessential in approaching this problem?
Best Regards,
D
The pressure differential is absolutely essential information.
You can use Bernoulli's equation and the continuity equation to solve for flow rate.
Likes HethensEnd25
Thank you for your insight. I have solved the problem. I will post my answer once I am home to double check.
Best Regards,
D
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
9K
