Particle Velocity and Distance in a Straight Line with -2v Acceleration
The discussion focuses on a particle moving in a straight line with an acceleration defined by the equation a = -2v m/s². Given initial conditions of v = 20 m/s at s = 0 and t = 0, the objective is to derive the particle's velocity as a function of position and determine the total distance traveled before coming to a stop. The solution involves using the relationship a = v (dv/ds) to express velocity in terms of displacement, leading to the integration of the velocity function.
  • Understanding of kinematics equations
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of differential equations
  • Concept of velocity as a function of displacement
  • Study the derivation of velocity functions from acceleration equations
  • Learn about integrating differential equations in physics
  • Explore the relationship between velocity, acceleration, and displacement
  • Investigate real-world applications of kinematic equations in motion analysis
This discussion is beneficial for physics students, educators, and anyone interested in understanding motion dynamics and kinematic equations in a straight line context.
AcecA
A particle is moving along a straight line such that its acceleration is defined as a = (-2v) m/s^2, where v is in meters per second. If v = 20 m/s when s = 0 and t = 0, determine the particle's velocity as a function of position, and the distance the particle moves before it stops.
Basic kinematics equations
I tried using dt = dv/a and integrating that, and I got t = (ln20 - lnv)/2, then I tried substituting it into s = s0 + v0t + (1/2)at^2, and now I'm stuck. Any help would be appreciated. Thanks :)
Use the fact that
a= \frac{dv}{dt}=v \frac{dv}{ds}
this will help you get velocity in terms of displacement.
Oh right. Thanks a bunch :)
  • · Replies 98 ·
