How Do You Calculate the Extension of a Spring Holding a 480 g Mass?
  • Thread starter Thread starter student333
    Mass Spring
The discussion focuses on calculating the extension of a spring holding a 480 g mass using Hooke's Law, where the elastic constant is 600 N/m. The correct formula to determine the extension (ΔL) is derived from the equilibrium condition, equating the spring force (kΔL) to the gravitational force (mg). The calculated extension is 0.00784 m, which does not match the provided solution of 0.0125 m, leading to the conclusion that the given solution may be incorrect.
  • Understanding of Hooke's Law (F = -ky)
  • Basic knowledge of gravitational force (mg)
  • Ability to perform unit conversions (grams to kilograms)
  • Familiarity with equilibrium concepts in physics
  • Review the derivation of Hooke's Law and its applications in real-world scenarios.
  • Explore the concept of equilibrium in mechanical systems.
  • Learn about potential errors in problem statements and how to verify solutions.
  • Investigate the relationship between mass, force, and acceleration in physics.
Students studying physics, particularly those focusing on mechanics and spring dynamics, as well as educators looking to clarify concepts related to Hooke's Law and equilibrium conditions.
student333
The elastic constant of a spring holding an object in equilibrium is 600 N/m. Find the extension of the spring with respect to its initial length if the object has a mass of 480 g.
hooke's law: F = -ky
I know that the answer is supposed to be 0.0125m, but I'm not sure as to how to arrive at this solution. I'm also a bit unclear as to how everything fits together (for instance, does initial length refer to the equilibrium position?), as I'm new to this concept. Could anyone please give a simple, straight-forward walk-through? Thanks!
The spring is vertical and the object hangs on it. The spring holds the object and prevents it from falling down. So what force exerts the spring on the object of mass m?
ehild
Does the spring exert a force of -ky on the mass? At equilibrium shouldn't this be equal to mg? How does this relate to the answer to the problem? If I set them equal and solve for y, I don't get the proper answer, so it seems that I'm missing something.
The magnitude of the spring force is kΔL and it acts upward. ΔL is the extension of the spring. Gravity is a downward force, mg. The forces have to cancel: mg=kΔL. What result did you get?
ehild
ΔL = (mg)/k = (0.48*9.8)/600 = 0.00784 m
but this doesn't match up with the given solution of 0.0125 m :confused:
Is 0.00784 the equilibrium position, and I am supposed to find the max distance past that point, perhaps? The question seems a bit vague to me, so I don't have a good grasp on what exactly I am looking for and how the equilibrium position fits in.
I think your answer is correct and the given solution is wrong. I can not understand the problem in a different way: The spring holds the object in equilibrium, given the force constant and the mass of the object.
It happens quite often that wrong solutions are given. Do not worry about it.
ehild
  • · Replies 22 ·
