Understanding the Voltage Across a Broken Lamp
The voltage across a broken lamp in a circuit can be measured as 12V due to the assumption of infinite resistance for the broken lamp. In this scenario, the intact lamp has a significantly lower resistance, causing the majority of the voltage to appear across the broken lamp. The first voltmeter reads 0V because there is no current flowing through the broken lamp, while the second voltmeter measures the full supply voltage of 12V across the broken lamp. This understanding is crucial for analyzing voltage distribution in series circuits.
  • Basic understanding of electrical circuits
  • Knowledge of Ohm's Law
  • Familiarity with voltage measurement techniques
  • Concept of resistance in series circuits
  • Study the principles of series and parallel circuits
  • Learn about Ohm's Law and its applications
  • Explore the concept of infinite resistance in circuit analysis
  • Investigate voltage division in electrical circuits
Students studying electrical engineering, educators teaching circuit analysis, and hobbyists interested in understanding voltage behavior in electrical systems.
Icy98
Why is the voltage across the broken lamp 12V?
Can I assume the broken lamp is of infinite resistance?
I understand the reading for the first voltmeter is 0V. But can anyone explain to me why the reading of the second voltmeter is 12V?[/B]
That would be a good way to look at it yes. How would the voltages then divide over the two light bulbs if there was a very small current present and the other intact light bulb has a much smaller resistance?
Most of the voltage will be across the broken one?
Correct.
Thank you![emoji3]
  • · Replies 23 ·
