Voltage amplification done by a transistor amplifier
4 replies · 2K views · last reply
Pushoam
Printed text reading: Example 8.1. A common base transistor amplifier has an input resistance of 20 Ω and output resistance of 100 kΩ. The collector load is 1 kΩ. If a signal of 500 mV is applied between emitter and base, find the voltage amplification. Assume α_ac to be nearly one.
Circuit schematic of a pnp transistor amplifier labelled Fig. 8.8: 500 mV source on the left driving emitter E with current I_E, base B with current I_B, collector C with current I_C, and load resistor R_C = 1 kΩ with V_out across it. R_in = 20 Ω and R_out = 100 kΩ are marked.
The equivalent circuit is drawn below.
It is assumed that the potential drop across the pn junction in forward bias is 0 V(I can't take it 0.7 V as the input voltage is 0.5 V). In this case the p-n junction is equivalent to a connecting wire-piece.
Since ##\alpha ## is nearly equal to 1, ##I_B# is taken to be 0.
Circuit schematic of a common-base transistor amplifier labelled Fig. 8.8(b), with a 500 mV source, emitter E, base B, collector C, Rin = 20 Ω, Rout = 100 kΩ, RC = 1 kΩ, and currents IE, IB and IC marked.
So, the current flowing through ##R_{in}## is ##I_E = \frac{500~mV}{20~\Omega} = 25 ~mA##
In fact, the above figure is wrong.Right?
It is the p-n junction in forward bias which should get replaced by Rin and np junction in reverse bias which should get replaced by Rout.
Then, the potential drop across the diode in forward bias is equal to the potential drop across the Rin i.e. 500 mV and the potential drop across the reverse bias is the potential drop across the Rout.
Potential drop across Rout = ## I_C R_{out} = 2500 V ##........(1)
Using Kirchoff's Voltage loop law, this voltage drop should be equal to the voltage drop across## R_C##.
But, due to Ohm's law, voltage drop across ##R_C = I_C R_C = 25V##......(2)
So, there is a contradiction.
In (1), I have considered the n-p junction as a linear element. I think this is wrong. The n-p junction could not be replaced by Rout. Then , in this case, there is no need to know Rout. Right?
So, does it mean that , in general, in transistor, the forward bias p-n junction could be taken as a linear element, but the reverse bias p-n junction has to be taken as a non-linear element?
The voltage amplification is : ## \frac{25V}{0.5V}=50##
  • Circuit schematic of a common-base transistor amplifier, Fig. 8.8(b), with a 500 mV AC source, Rin = 20 Ω, Rout = 100 kΩ, Rc = 1 kΩ, and Vout across Rc.
I'm a bit rusty but...
Potential drop across Rout = ICRout=2500VICRout=2500V I_C R_{out} = 2500 V ........(1)
No that's not correct. The output looks like a dependent current source with the 100K output impedance in parallel. So the 1k load resistor is in parallel with the 100K output impedance.
Small-signal equivalent circuit of a transistor amplifier with source vs and Rs, input Rin, controlled current source gm vπ, output resistance ro, collector resistor RC, load RL, and output voltage vo.
I agree that IE = 25mA
IB is small so IC = IE = 25mA
The output impedance is high compared to the load so the output impedance can be ignored.
So the voltage across RC is 25mA * 1K = 25V
So the voltage gain is 25/0.5 = 50.
O.K.
So, in the equivalent circuit, the forward bias p-n junction gets replaced by an input resistance in series while the reverse bias junction gets replaced by an output resistance in parallel.
The output circuit acts as a current source with current ##I_C##.
Equivalent circuit of a common-base transistor amplifier: a 500 mV source with emitter current I_E through R_in = 20 Ohm to node B, current I_B to node O, current I_C to node M, with R_out = 100 kΩ in parallel and R_C = 1kΩ with Vout across it.
Is this right?
No, I would simplify the transistor model to an amplifier model and draw it like this...
Simplified amplifier model circuit: source vs on the left feeds Rin labeled 20R with current Ie, a current-controlled current source in the middle with output current Ic=Ie, Rout 100k in parallel, and load RL 1K on the right.
When the problem statement says the input resistance is 20R you shouldn't think of the circuit as a transistor and a separate 20R resistor. The 20R results from combining the effects of the transistor, it's bias circuit, feedback, base current (eg the whole thing) into one amplifier parameter for the input.
I got it.
The problem is with the connection at B in my circuit. The connection at B implies that ##I_B >>I_C##.
Thank you.
