Voltage vs Potential Energy Formulas
5 replies · 10K views · last reply
[V]
I am having a hard time figuring out the signs for some of these formulas:
First of all, U=Potential Energy
[tex]V=\frac{U}{q}[/tex]
[tex]\int F dr = \int Eq dr = - Work[/tex]
Since,
[tex]Work=K=-U[/tex]
Therefore
[tex]\int Eq dr=+U[/tex]
[tex]U=\frac{QqK}{r}[/tex]
Therefore,
[tex]V=\frac{KQ}{r}[/tex]
BOTH U & V have a positive slope of 1/r.
So far, everything checks out. But when I want to find the ΔV across a distance of a parallel plate capacitor, something seems to break down...
[tex]\int E dr = V[/tex]
Since E is constant here:
[tex]E\int dr = V[/tex]
I take the derivative WRT to 'r'
[tex]E=\frac{dv}{dr}[/tex]
[tex]dV=E * dr[/tex]
What is the potential difference between 20cm and 40cm in the uniform 3000 (V/m) electric field?
The answer is -600V. I don't fully understand why it is negative!
The equation I just drived, ΔV=EΔr gives me a positive value!
How do you justify this negative number in the end? Please explain with calculus terminology if possible.
Are all my assumptions up until this point correct?
Hi [V]! :smile:
You've lost a minus …
U = -Qqk/r (= ∫-∞r Qqk/x2 dx) :wink:​
Ahh! Cant be!
[tex]\int_i^f F dr = (-\frac{KQq}{r_{f}})-(-\frac{KQq}{r_{fi}})[/tex]
[tex]W=-(\frac{KQq}{r_{f}}-\frac{KQq}{r_{fi}})[/tex]
[tex]\Delta U=-W[/tex]
[tex]\Delta U=\frac{KQq}{r_{f}}-\frac{KQq}{r_{fi}}[/tex]
[tex]U=\frac{KQq}{r}[/tex]
Correct?
Hi [V]! :smile:
Sorry, you're right, I was getting confused with gravitational potential. :redface:
The error was in your equation …
… potential energy = minus work done by a conservative force
electric potential = minus work done per charge
so V = -∫ E dr :wink:​
Thank you! :)
Soo
[tex]V = -\int E dr[/tex]
If I derive both sides, I get
[tex]\frac{dV}{dr}=-E[/tex]
[tex]E=\frac{-\Delta V}{\Delta r}[/tex]
With this equation, my other problem seems to work.
However, now this presents another problem!
Using this relation, I want to find the Capacitance of a parallel plate capacitor.
Given that
[tex]E=\frac{Q}{\epsilon_0A}[/tex]
And
[tex]C=\frac{Q}{\Delta V}[/tex]
Therefore, using the relation I just proved in the previous stepped:
[tex]\frac{-\Delta V}{\Delta r} = \frac{Q}{\epsilon_0A}[/tex]
Solve for Q
[tex]Q=-\frac{\epsilon_0A\Delta V}{\Delta r}[/tex]
[tex]C=\frac{Q}{\Delta V}=-\frac{\epsilon_0A}{\Delta r}[/tex]
then just replace variables to match my literature...
[tex]C=-\frac{\epsilon_0A}{d}[/tex]
But Waiit!
My textbook says it is positive!
They seem to be using this relationship to derive this equation:
[tex]E=\frac{\Delta V}{d}[/tex]
They use different variables, but why is it positive? I thought I just proved earlier that it should be :
[tex]E=-\frac{\Delta V}{d}[/tex]
hi [V]! :smile:
[V];3200429 said:
Using this relation, I want to find the Capacitance of a parallel plate capacitor …
let's measure all displacements from the -ve to the +ve plate …
then D and E are negative, D = -Q/A, E = -Q/ε0A …
the potential difference from the -ve to the +ve plate is V = -∫ E.dx = ∫ Q/ε0A dx = xQ/ε0A
(to put it in more general terms, E goes from +ve to -ve, so the work done from the -ve to the +ve plate must be negative, and the potential difference must be positive)
