Voltmeter relative error question. (Computer Controlled Measurement)
To calculate the relative error of a voltmeter measuring 50V with a maximum input of 300V, the initial attempt yielded a relative error of 0.0016%. However, voltmeters typically have both absolute and percentage of full scale errors that must be considered. In this case, with an absolute error of 0.1V and a 0.1% full scale error, the total error is calculated to be +/- 0.4V, resulting in a relative error of +/- 0.8%. The original poster later confirmed that their teacher acknowledged the oversight in the question's completeness. Accurate error calculations are essential for reliable voltage measurements.
Marketgirl
You measure 50V with a voltmeter, which has 300V as the max. input voltage. What will be the relative error (h%) of the measurement?
hi i divided 50v / 300 V and get = 1,66 and divided it by 100 to get relative error in % and get %0.0016 just wanted to know my answer is correct or not thank you from now.
Hard to say. As in 'impossible' with what you gave us.
Voltmeters usually have an absolute voltage error plus a "% of full scale" error. So if the
reading is 50V, the absolute error is 0.1V and the % of full scale is 0.1% the error would be +/- (0.1V + 300*0.001V) = +/- 0.4V. So the 'relative eror' of your measurement would be +/- 0.4/50 = 0.8%.
just got an email from the teacher he is mistaken he haven't complated the question and i solved it anyway thanks for your helps
