Volume by disks, shells, or washers?
  • Thread starter Thread starter KMcFadden
    Volume
Determining the volume of a solid using disks, shells, or washers depends on the shape and characteristics of the solid. The shell method is often preferred for complex shapes, while the disk method is suitable for simple shapes without holes. If a hole is present, the washer method is applicable. The choice of method can also be influenced by which produces a more manageable integral for evaluation. Ultimately, the decision relies on the specific functions that define the region being revolved.
KMcFadden
What is the easiest way to determine if the volume of a solid should be found by using disks, shells, or washers?
Personally I always start with the shell method unless it is a really basic, simple shape(disk method)... But to answer ur question, I look for a hole. If there is one, then i am thinking washer, if there isn't and the solid is a very simple shape, then I go with the disk method. For the most complex shapes, i automatically go to the shell method.
There is no one-size-fits-all guidance here. It depends on the function/functions that bound the region being revolved. The disk and washer methods are essentially the same, with the washer method being used if the typical volume element is a disk with a hole in it.
Sometimes one method produces an integral that's easier to evaluate, and sometimes another method does.
36K
