Volume created by the revolution of a polar function around the initial line
The discussion focuses on deriving the volume created by rotating a polar function around the initial line, specifically addressing the formula for surface area of cones. The user attempts to apply cone shell methods to calculate volume but realizes that the integral derived does not yield the correct volume for a circle defined by r=1, resulting in an incorrect volume of 2π instead of the expected 4/3π. The conversation highlights the need for accurate integration techniques in polar coordinates to achieve correct volume calculations.
  • Understanding of polar coordinates and polar equations
  • Knowledge of calculus, specifically integration techniques
  • Familiarity with the surface area of cones and cylindrical shells
  • Basic concepts of volume calculation in three-dimensional geometry
  • Study the derivation of volume using polar coordinates in calculus
  • Learn about the method of cylindrical shells for volume calculations
  • Explore the application of integrals in calculating volumes of revolution
  • Investigate the differences between cone and cylindrical shell methods in volume derivation
Mathematics students, educators, and professionals involved in calculus, particularly those focusing on volume calculations in polar coordinates and geometric applications.
progressive
Hello,
I was wondering if anyone could help me with deriving the volume created by the rotation of a polar equation around the initial line.
So, I thought about adding the surface area of cones (multiplied by [tex]d\theta[/tex]) if each cone the triangle created with s-length of [tex]f(\theta)[/tex] and r-length of [tex]f(\theta)sin(\theta)[/tex].
Basically, this was entirely premised that cone shells could work exactly like cylindrical shells when trying to find volume - but I don't think it works.
The formula for the surface area of a cone (not including the circle at the bottom) is [tex]\pi*r*s[/tex].
http://math.about.com/od/formulas/ss/surfaceareavol_2.htm" is a site that has info on r and s.
So if I wanted to rotate the circle r=1 around the initial line but only from [tex]0<\theta<{\pi}[/tex], then the integral summing the cone surface areas could be expressed by:
[tex] \int_0^\pi \pi*r*s*d\theta =<br /> \int_0^\pi \pi f(\theta)*f(\theta)*sin(\theta) d\theta =<br /> \int_0^\pi \pi f(\theta)^2 sin (\theta) d\theta[/tex]
I spent a lot of time on this problem, including looking at spherical sectors - circular sectors are needed to calculate the *area* of a polar graph.If anyone could help me with this derivation, it would help me significantly. Thanks so much for your help and time!
Hello again,
I forget to say that the integral I mention above does not calculate the correct volume e.g. for a circle r=1. It gives a volume of 2pi, when it should be 4/3 pi.
Thanks again for any help you can offer!
  • · Replies 30 ·
16K
