What is the volume inside an ellipsoid between two intersecting planes?
The discussion centers on calculating the volume between the planes \(y=0\) and \(y=x\) within the ellipsoid defined by \(\frac{x^2}{a^2} + \frac{y^2}{b^2} + \frac{z^2}{c^2} = 1\). The correct approach involves a change of variables to spherical coordinates, leading to the volume integral \(V=abc \frac{2\pi}{3} \arctan{\frac{b}{a}}\). The confusion arises from the limits of integration for the angle \(\theta\), where the correct limit is \(\tan^{-1}(a/b)\) instead of \(\pi/4\). This adjustment is crucial for accurately visualizing the intersection of the planes and the ellipsoid.
  • Understanding of ellipsoids and their equations
  • Familiarity with spherical coordinates and volume integrals
  • Knowledge of trigonometric functions, specifically arctangent
  • Basic calculus, particularly triple integrals
  • Study the derivation of volume integrals in spherical coordinates
  • Learn about the properties of ellipsoids and their transformations
  • Explore the application of arctangent in geometric contexts
  • Practice solving volume problems involving intersecting planes and solids
Students in advanced calculus, mathematicians, and anyone involved in geometric volume calculations, particularly those dealing with ellipsoids and spherical coordinates.
JD_PM
Find the volume between the planes ##y=0## and ##y=x## and inside the ellipsoid ##\frac{x^2}{a^2} + \frac{y^2}{b^2} + \frac{z^2}{c^2} = 1##
I understand we can approach this problem under the change of variables:
$$x=au; y= bv; z=cw$$
Thus we get:
$$V= \iiint_R \,dxdydz = abc\iiint_S \,dudvdw$$
At this point the ellipsoid has become a sphere. Thus we could use spherical coordinates to compute the volume.
My issue is with the extremes of the integral; concretely with the $\theta$ angle. I would set up the integral like this:
$$\int_{0}^{\pi / 4} d\theta \int_{0}^{\pi / 2} d\phi \int_{0}^{1} dr$$
But the stated solution is:
$$\int_{0}^{\tan^{-1} (a/b)} d\theta \int_{0}^{\pi / 2} d\phi \int_{0}^{1} dr$$
My extremes make sense to me; it is just about visualizing a sphere and two intersecting planes. But ##\tan^{-1} (a/b)## confuses me.
What's wrong and why?
Hi,
It would appear that if ##\ \ y = x \quad \Rightarrow\ \ \arctan(1) ## is a bound for the coordinates before the change. Guess what the corresponding bound is afterwards ?
Thus we get:
Assuming that ##\theta## is the polar angle, the volume element in spherical coordinates is ##r^2 \sin \theta \, dr \, d\theta \, d\phi,## so you should have ##\int_0^1 r^2 \, dr,## not ##\int_0^1 dr.##
In polar ( spherical ) coordinates ... is not simple $$ d\theta\space d\phi \space dr $$
but $$ r d\theta\space r\sin \theta d\phi \space dr $$
Let me find the picture ... aa here it is ..
But also you can do it without calculus ( to check the result ) by careful thinking
if you compress ellipsoid
in x direction by a times
in y direction by b times
in z direction by c times you will get nice round ball
you want to calculate volume of the slice of ball between
y=0 ... x, z plane and
x/a=y/b plane => b/a=y/x
##\theta## goes from 0 to ## \arctan{ \frac{b}{a}} ##
Volume of the ball with radius r=1 is ##V= \frac{4\pi}{3} ##
Volume of the slice is ##V= \frac{4\pi}{3} \space \frac{\arctan{\frac{b}{a}} }{2\pi} ##
##V= \frac{2\pi}{3} \arctan{\frac{b}{a}}##
and when you stench back the ball to the ellipsoid
##V=abc \frac{2\pi}{3} \arctan{\frac{b}{a}}##
  • · Replies 19 ·
