Volume of Stone submerged in Water
The discussion revolves around determining the volume of a submerged stone based on its weight in and out of water, utilizing principles of buoyancy and density. The problem involves concepts from fluid mechanics and gravitational forces.
  • Participants explore the relationship between the weight of the stone in water and its weight in air, questioning why there is a difference. Some discuss the application of buoyancy and the calculation of volume using the weight difference and gravitational acceleration.
Participants are actively engaging with the problem, clarifying the use of gravitational acceleration in their calculations. There is acknowledgment of progress in understanding the relationship between the weight difference and the volume of displaced water, although some confusion remains regarding numerical accuracy.
There is an ongoing discussion about the correct value of gravitational acceleration to use in calculations, with some participants noting discrepancies in their computations. The implications of Archimedes' principle are also being explored in relation to the problem.
scbeturner
A submerged stone weighs 254N, but out of the water it weighs 1235N. The density of the water is 1000 kg per cubic meter. What is the volume of the stone?
I understand that density=mass/volume but I don't know which numbers to plug in and I can't find help anywhere!
Why does the stone weigh less when it's submerged in water? What does the weight difference represent?
Because of the buoyancy force??
i took the difference between the weights which is 981N, divided it by 98.1 and got 10, then divided it by 1000 and got .01 is that right?
Yes, that's correct.
Why 98.1? What is 98.1?
The force of gravity to convert it from Newtons to kilogram
The acceleration due to gravity is 9.81 m/s2.
So should I not have used it as the conversion factor?
Yes, you want to use the acceleration due to gravity in the conversion. But the value you employed was 10x to large. You used 98.1 rather than 9.81.
Sorry that's what I meant
So I on the right track?
Yes, you're on the right track.
Once you realized that the weight difference represents weight of the water displaced by the stone, you were on the right track to find the volume of the stone by finding the volume of that displaced water.
so how do i use the volume of the displaced water to find the volume of the stone?
Archimedes' principle of displacement -- the volume of water displaced by a submerged object is equal to the volume of the object...
oh ok so .01 cubic meters is the answer?
No, that's still off by a factor of 10. Did you fix your value of g?
with that fixed the answer comes out to .1 cubic meters correct?
That looks better :wink:
haha ok thanks!
  • · Replies 22 ·
  • · Replies 25 ·
  • · Replies 17 ·
  • · Replies 16 ·
