Volume Question with cirular base and square top
The volume of a solid with a circular base of radius 1 and square cross-sections perpendicular to the base is calculated using integration. The area of each square cross-section is expressed as A(x) = 4(1-x²), leading to the volume function V = 2 ∫₀¹ 4(1-x²) dx. The correct volume is determined to be 8/3 cubic units after proper integration. The shape is confirmed to be distinct from a cylinder due to the nature of the cross-sections, which are squares rather than rectangles.
  • Understanding of integral calculus
  • Familiarity with cross-sectional area calculations
  • Knowledge of geometric shapes and their properties
  • Ability to visualize three-dimensional solids from two-dimensional representations
  • Study the process of calculating volumes of solids of revolution
  • Learn about the application of the disk and washer methods in integration
  • Explore the properties of geometric shapes with varying cross-sections
  • Investigate the implications of different cross-sectional shapes on volume calculations
Mathematics students, educators, and professionals involved in geometry, calculus, and engineering who seek to deepen their understanding of volume calculations for complex shapes.
ktpr2
The question goes like this:
"The base of a certain solid is circular with a radius of 1. Cross-sections of the solid, perpendicular to the base, are square. Find the volume of the solid."
In visualizing this object, i see that it looks like a "blocky" foot ball, where the perimeter is circular, but the corners are sharp because of the volume of the reducing square outward from the center.
I center the circle at zero on the xy plane. Then I note that base of a given slab can be given by 2 \sqrt{1-x^2}. Since the area of a sqaure is b^2, A(x) = 4(1-x^2). The slab has a width \Delta x, making the total volume function 4 (1-x^2) \Delta x. I then integrate from 0 to 1 and double the resultin volume, as 0 to 1 represents the volume of half this shape. My result is 2 \int_{0}^{1} 4 (1-x^2) \Delta x = \frac{32}{3} cubic units.
Is this logic correct? If not, why?
Look at the picture. What is the name of that shape of solid? :smile:
Why can't the imaginary shape be a cylinder with height equal to the diameter of the base?
PS: Ehild already mentioned it.
Um, isn't that just a cylinder then? And I suppose i introduced an extra constraint; the cross sectino is never said to decrease.
It is! :smile:
ehild
The figure in the original problem is not a cylinder because, if it were, the cross sections would be rectangles, not squares (the cross section at the diameter would be a square but as you move toward the ends of the diameter at right angles to your cross sections, the base length gets smaller- with a cylinder the height doesn't).
ktpr2 was right the first time- it's a sort of "blocky" football.
Set up a coordinate system so that the origin is at the center of the circular base. The equation of the circle is x2+ y2= 1. Imagine the cross-sections to be perpendicular to the x-axis (so parallel to the y-axis). The base of each cross-section runs from the circle above the x-axis to the circle below the x-axis: the length is 2y and so the area of the square cross-section is 4y2. That is: 4(1- x2). The "thickness" of each imaginary cross-section is dx (since we are "moving" along the x-axis). The "sum" of those becomes the integral 4\int_{-1}^{1}(1- x^2)dx
There is nothing wrong with your logic, but you need to check your integration. This shape is not a cylinder. Also, when writing integrals we use differentials, not deltas
V = 2 \int_{0}^{1} 4 (1-x^2) dx = 8 \int_{0}^{1} (1-x^2) dx = \ \ \?
OOPs. Halls beat me to it.
Sorry, I overlooked the "square top". Does that shape then look like in the picture? Now I am not sure, either, what "cross section" is.
ehild
ehild
That's really not it either. It does not have a flat top. It's more like a cylinder of length 2 and radius 1 that has been cut by a saw with a blade in the shape of half a 2 by 4 ellipse with the long axis of the ellipse parallel to the axis of the cylinder. You have to use a little imagination, but the first figure is an approximation showing only the positive x half of the solid. The corners of the squares are rounded in the figure, as if the cut out shape had the sharp edges sanded round. The actual shape has sharp corners. Draw vertical lines from the rounded corners down the the base to complete the square cross sections. Those extended lines to the base would lie on the circle at the base.
I changed the coordinates so that I could do a better looking plot. The second figure is a pretty fair rendition of the shape of half of the solid. The third shows just about all of it.
