W=(1/2)KA^2 Can someone explain this equation in detail & Q
  • Thread starter Thread starter PoohBah716
    Explain
The discussion revolves around the equation W=(1/2)KA^2, which relates to the potential energy stored in a spring when compressed. The problem involves a mass on a frictionless surface attached to a spring, requiring the determination of the spring constant and mass based on given energy and compression values.
  • Participants discuss the derivation of the equation W=(1/2)KA^2 and the relationship between work done on the spring and potential energy. There are attempts to connect Hooke's Law to the problem and questions about the significance of the squared amplitude in the equation.
Some participants have provided hints and guidance for deriving the equation, while others have expressed a desire for deeper understanding of the concepts involved. There is an ongoing exploration of the relationship between force, work, and potential energy in the context of spring mechanics.
Participants are encouraged to derive the equation themselves, and there is a note about the importance of understanding the underlying principles rather than simply obtaining the answer. The discussion reflects a mix of attempts to clarify concepts and provide foundational insights.
PoohBah716
A mass resting on a horizontal frictionless surface is attached to one end of a spring. 3.6 J to compress spring 0.13 m. released at max acceleration 15 m/s. What is the spring constant and mass
I would like to dicuss this question how the equations are derived. can someone give me there explainantion of the problem attached?
W=(1/2)KA^2
426 n/m and 3.7 kg
Try to derive it yourself. Ill give you a hint. Restoring force applied by a spring is directly proportional to its contraction/expansion in the direction to attain natural length. F=-Kx, also work done is F. dx. Try getting an answer
I know using Hookes law can be used after finding the mass. I want to know more how W=1/2KA^2 is derived in this solution. My understanding is W is the potential energy the and A^2 is the amplitude and the reason it is square because ?
You have an expression for the force ##F## exerted by the spring when it is compressed to length ##x## (Hooke's Law). How would you compute the work needed to compress the spring from its natural length to a smaller length?
Note: you should make a serious attempt to understand what is being asked here, and how to do it.
Well, whatever force we apply on the spring to contract it is stored in the spring as its potential energy. So the work done in compressing the spring is F.x. Where x is the compression in the spring. As the force varies with the compression(kx) here we calculate the work done for elemenal compression dx. Work done dw=potential of spring =F. dx=-Kx.dx.
As the force is opposite to the elemental compression dW=Kxdx.
Integrating with limits from 0 to x. We get W=integration(kxdx) =1/2Kx^2.
Good.
Ray,
I have the impresssion Abhi made a good start inviting OP to find out for himself and then spoilt the fun by providing the answer !
PB: is it clear to you now ?
