Wait 24 hours before powering up A/C or fridge?
  • Thread starter Thread starter DaveC426913
The discussion revolves around the necessity of waiting 24 hours before powering up a refrigerator or air conditioning unit after transport, installation, or power failure. Participants explore the implications of this recommendation, including potential risks to the appliance and the rationale behind the guideline.
  • Some participants suggest that the 24-hour wait is a precautionary measure related to compressor lubricating oil, which may have shifted during transport, potentially leading to damage if the unit is powered on too soon.
  • Others argue that it is not always necessary to wait after transport, as the arrangement of refrigerant and lubrication may not be significantly affected.
  • A participant mentions that manufacturers may recommend the wait to protect themselves legally, rather than due to a strict necessity.
  • Concerns are raised about the practicality of waiting, especially if the appliance does not operate correctly after installation, leading to potential food spoilage.
  • Some participants share anecdotal experiences, noting that older refrigerators had different operational requirements, and that modern units may not require the same caution.
  • There is a discussion about the relevance of similar precautionary rules in other contexts, such as turning off devices during airplane takeoff, questioning whether these rules are based on necessity or tradition.
Participants do not reach a consensus on whether the 24-hour wait is necessary. Multiple competing views are presented regarding the risks and rationale behind the recommendation.
Participants express uncertainty about the specific conditions under which the wait is necessary, and there are references to varying practices among service providers regarding appliance testing.
DaveC426913
2025 Award
TL;DR
This is always recommended by manufacturers. Is it necessary?
Is it just a precautionary thing? I mean, it can't hurt to wait 24 hours, but is it necessary?
DaveC426913 said:
TL;DR: This is always recommended by manufacturers. Is it necessary?
After power failure? Purchase? Installation? What's the circumstance? The appliance hasn't magically appeared in place....
Apparently it has to do with the compressor lubricating oil. During transport and setup the unit may have been tipped allowing the oil to flow out of the compressor into the closed refridgerant lines leaving the compressor with little to no lubrication.
Turning the compressor on prematurely could damage the unit. It could overheat or moving parts would suffer excessive wear and tear.
The manufacturer doesn’t know how the unit was treated and so places a warning to not turn the unit on for at least 24 hrs to let the lubricating oil to settle.
It also allows the manufacturer some legal cover should they deny expensive warranty repairs because the customer didn’t follow recommendations.
  • Agree
It is not always necessary after transport.
It supposedly gives the liquid refrigerant, gas, and the lubrication, a chance to arrange its place in the system following the disturbance.
Oops. Anytime is has been moved.
This is much like what I hear, yes.
Baluncore said:
supposedly
This is the crux of my question: supposedly.
I guess it is an intractible question.
It can't hurt to tell consumers to leave a device to settle for 24 hours. And no one is going to say 'no, go ahead, bounce it off a tampoline then fire it up immediately!'
It's like a zombie rule. It will live on whether or not it remains necessary. (A bit like requiring passengers to turn electronic devices off during takeoff.)
  • Agree
If your new refrigerator does not start to operate correctly, the manufacturer would tell you to turn it off for 24 hours, but by then, the food would have been wasted. So they tell you up front to keep it off for 24 hours, to cover their proverbials. They know you will turn it on immediately and check it is working before putting food in it. If it does not work, you will turn it off for 24 hours, like they suggested, and it will fix itself.
Here is a similar example.
In PF, when you change your watch status on a thread, the menu bar becomes unavailable for about 3 seconds, covered by an unnecessary "your changes have been saved" banner. Is it always necessary to delay, or is the manufacturer, Greg, enforcing the wait because sometimes it is necessary, to prevent PF from getting its notification knickers in a knot?
Baluncore said:
If your new refrigerator does not start to operate correctly, the manufacturer would tell you to turn it off for 24 hours, but by then, the food would have been wasted. So they tell you up front to keep it off for 24 hours, to cover their proverbials. They know you will turn it on immediately and check it is working before putting foot in it. If it does not work, you will turn it off for 24 hours, like they suggested, and it will fix itself.
I'm not sure if that answers my question...
Is it true that I risk damaging my fridge/AC if I turn it on without waiting 24 hours?
I don't think it will be damaged, but it may not cool properly.
There were some fridges in the 1960s that would stop working. Turning them off and upside down for 24 hours would fix them.
Some AC systems can reverse themselves internally, and freeze the house solid in winter. Turning them off for 24 hours can fix those.
In the days that people often used fridges with 'Absorption' units. the mix of fluids and the way they move around was a bit more subtle and I could imagine that a good shake would do some serious aggro as the natural convection could really be upset.. It's rare that a fridge would be rotated 'over-horizontal' so a short pause would probably be enough. The pump is always (?) at the bottom.
They work fine on sailing boats.
I asked my wife about this. She works with service providers that install new refrigerators and HVAC systems. She said that they test them right away when they install them, and don't wait 24 hours before having to go back to the home to do the test. They probably are real careful about not tilting the units when transporting from the distributor to the home, though.
I've always heard that if laid down on its side to turn it upright and wait the same amount of time that it was laid over. Of course there would be a limit. Imagine your brother leaves you in charge of watching his house while he's on a three week vacation. You play the practical joke the day he leaves and turn his fridge on its side. Sorry bro, going to have to wait three weeks to use the fridge now that you're back.
With respect to the turn off your devices on airplanes rule. Veritaseum did a video on it. Basically, it wasn't because it affected flight comms, it was because the engineers believed it would cause havoc with cell towers as your phone traveling at 600 mph waltzes its way through tower after tower never able to maintain a connection.
However, cell towers are focused more on the ground than up in the sky and so it really wasn't an issue but the rule stuck even today. I think the airlines realized that passengers would get upset if a seatmate were on the phone talking up a storm.
I do know many frequent business travelers prefer it that way. It's the one time you're not tethered to your office and can actually work or rest. Your choice.
Why would airlines pick up that ball and run with it? That seems like a Somebody Else's Problem problem.
I respect Veritasium , but is the story confirmed or speculative?
Yes. A totally fake rationale. Not truth.
(Not that I disagree with the outcome - take off and landing is a good quiet time.)
But I'm after truth here, as opposed to lies-to-children.
It's not as straightforward as that. Cruising at a height of 9 - 12 km the geometry (hexagonal - ish) of ground cells would no longer apply. You're not just cruising through cells. The plane could be getting similar signal levels from several stations at once so the inverse square law would not be working as the designers planned. The selection algorithms in the base stations could well be operating at cross purposes.
  • · Replies 30 ·
