Water flow in pipe with two open vertical offshoots
15 replies · 5K views · last reply
rlc
Water (η = 1.00E-3 Pa·s) is flowing through a horizontal pipe with a volume flow rate of 0.0125 m3/s. As the drawing below shows, there are two vertical tubes that project from the pipe. Assume that H = 0.0458 m and L = 0.738 m.
Calculate the radius of the horizontal pipe.
I've seen this problem posted on this website before, but the solution there didn't work for me.
I know you should use Poiseuille's Law, but what do you do about the pressures?
Do you know how to determine the pressure difference between the two locations in the pipe? If so, what is it?
Chet
rlc said:
No, but I know it is part of Poiseuille's Law.
You don't need to use Poiseuille's law to find the pressure difference between the two locations in the pipe. You already have enough information to determine it. In those two vertical offshoots, is the fluid static or is it flowing?
Chet
It would be static? Since it is open and the water wouldn't really go anywhere?
rlc said:
Would the pressure difference just be H?
H is what we would call the difference in static pressure head. Do you remember the equation for static pressure as a function of depth? (It involves density and g).
Chet
rlc said:
roh*g*h
Yes. That's right. Then what is the pressure difference between the two locations in the pipe in Pa?
Chet
rlc said:
I'm sorry, but I don't know
ρ=1000 kg/m3 (for water)
g = 9.8 m/s2
Δh= H = 0.0458 m
ΔP=ρgΔh (in units of Pa = kg/ms^2)
What do you get for ΔP?
rlc said:
(1000)(9.8)(0.0458)=448.84 Pa
Oops. You already got it.Right. That's the pressure difference between the two locations.
Now, can you write down the Poiseulle equation for the pressure difference between the two locations in terms of the volumetric flow rate, the viscosity, the distance L, and the tube diameter D?
Chet
Q=[(pi)R^4(roh*g*H)]/8nL
0.0125=(pi*R^4*448.84)/(8*1.00E-3*0.738)
R^4=5.23377E-8
R=0.015125 m
R=1.51 cm (which LONCAPA says is the correct answer)
Thank you so much for responding to me!
