How Does a Resistor Affect the Heating Time of Water?
The discussion focuses on the relationship between resistor values and the heating time of water, specifically using the formula $$R=\frac{\Delta t(\Delta V)^2}{Q}$$ to derive the resistance value of 8.33 Ω. Participants analyze the heating time, concluding that the total time to heat water from 20°C to 100°C and then boil it must be considered separately. The calculations involve the heat transfer equation $$Q=mc\Delta T$$ and the latent heat of vaporization $$L=2.26\times10^6\,J/kg$$, highlighting the importance of temperature in the calculations.
  • Understanding of Ohm's Law and resistance calculations
  • Familiarity with thermodynamic principles, particularly heat transfer
  • Knowledge of specific heat capacity and latent heat concepts
  • Ability to manipulate and solve equations involving multiple variables
  • Study the derivation and application of the heat transfer equation $$Q=mc\Delta T$$
  • Learn about the latent heat of vaporization and its significance in phase changes
  • Explore the effects of resistance on heating elements in electrical circuits
  • Investigate the relationship between voltage, current, and power in heating applications
Students and professionals in physics, electrical engineering, and thermodynamics, particularly those interested in heat transfer and electrical resistance in practical applications.
archaic
An electric water heater which is well-insulated warms 107 kg of water from 20.0°C to 45.0°C in 27.0 min.
Find the resistance (in Ω) of its heating element, which is connected across a 240 V potential difference.
How much additional time (in min) would it take the heater to raise the temperature of the water from 45.0°C to 100°C?
What would be the total amount of time (in min) required to evaporate all of the water in the heater starting from 20.0°C?
$$P=\frac{(\Delta V)^2}{R}=\frac{Q}{\Delta t}$$
1)$$R=\frac{\Delta t(\Delta V)^2}{Q}=\frac{\Delta t(\Delta V)^2}{mc\Delta T}=8.33\,\Omega$$2)$$\Delta t'=\frac{mcR\Delta T'}{(\Delta V)^2}=\frac{\Delta T'}{\Delta T}\Delta t=59.4\text{ min}$$3) I surfed the net a bit and have found a post on physics.stackexchange in which it is mentioned that the amount of water evaporated is related to the heat by ##Q=Lm##, where ##L=2.26\times10^6\,J/kg##. I used it to get$$P=\frac{(\Delta V)^2}{R}=\frac{dQ}{dt}=L\frac{dm}{dt}\Leftrightarrow\frac{(\Delta V)^2}{R}\Delta t=Lm\Leftrightarrow\Delta t=\frac{RLm}{(\Delta V)^2}$$but this surely is wrong (no taking account of the temperature, and gives a result less than the previous one). Any ideas please?
I really don't know much about thermodynamics.. I thought of ##Q=mc\Delta T## because it was shown in an example in the same chapter I am going through (Currents etc). :sorry:
Not that I can see. Show the calculation (with units please). I believe the equation is correct.
$$\Delta t=\frac{8.33[\frac{kg\,m^2}{s\,C^2}]\times107[kg]\times2.26\times10^6[J/kg=m^2/s^2]}{240^2[J^2/C^2=kg^2m^4/s^4]\times60[s/\text{min}]}=582.85\times\frac{kg\,m^2\,kg\,m^2\,C^2\,s^4\text{ min}}{s\,C^2\,s^2\,kg^2\,m^4\,s}$$I was wrong in my calculations earlier, but this is still wrong. The HW platform won't accept it (it wants it in minutes).
Seems reasonable to me. They want the " heat up" part too I think.
What bugs me is that the question says "starting from 20 degrees C", while my expression has no room for temperature.
Its two parts: heat the water to from 20 to 100C and then boil it!
where is my brain.. :nb)
thank you!
  • · Replies 27 ·
