Water Pump Pressure: Investigating Load Failure in Engine Systems
The discussion revolves around the pressure inside a water pump for engine systems, with a focus on investigating load failure. Participants explore the specifics of pressure measurements and their implications in automotive contexts.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant inquires about the specific pressure levels within a water pump, indicating an interest in load failure investigations.
  • Another participant notes that in automotive applications, the radiator cap typically withstands about 12 PSI before relieving pressure, suggesting limited differential pressure in water pumps.
  • A later reply provides a resource link to a library on fluid mechanics, indicating a potential avenue for further research on pump pressures.
  • Participants express varying levels of clarity regarding the initial question, with one noting it as vague.
There is no consensus on the specifics of water pump pressure, and the initial inquiry is considered vague by some participants. Multiple perspectives on the topic remain without resolution.
The discussion lacks detailed definitions of terms and specific assumptions regarding the context of pressure measurements in different engine systems.
Individuals interested in automotive engineering, fluid mechanics, and those investigating load failures in engine systems may find this discussion relevant.
Eng.Naif
Hi,,
I want to ask you about how much pressure inside the water pumb for the engine??,
because I want to investigate the load failure?
Pretty vague question. In the automotive world the radiator cap will withstand about 12 PSI before the cap relieves pressure and dumps into the overflow tank. There isn't likley a lot of differential between input and output pressure of the water pump.
Thank you my friend ,,,
vague!
I can give you a usefull website where you can find about pressure inside a pump :
look at this library.
http://www.firavia.com/mecheng.html
Fluid mechanics section
thank you firavia ;
it really useful library ,,,
thank you so much
  • · Replies 29 ·
10K
  • · Replies 37 ·
  • · Replies 26 ·
