Understanding Wave Amplification for Light & EM Radiation
  • Context: Graduate
  • Thread starter Thread starter mjasin
    Amplification Wave
This discussion focuses on wave amplification principles in electromagnetic (EM) radiation, particularly visible light. It confirms that coherent light sources, such as lasers, produce interference patterns when intersected, while incoherent sources result in increased irradiance without amplification. The conversation also explores the concept of coherence beyond lasers and the potential for non-linear effects to generate new wavelengths under specific conditions. The participants emphasize that the intersection of non-coherent sources primarily leads to additive irradiance rather than altered wavelengths.
  • Understanding of wave interference and coherence in light sources
  • Familiarity with electromagnetic radiation principles
  • Knowledge of non-linear optics and its effects on light
  • Basic concepts of irradiance and its measurement
  • Research the principles of coherence in various EM sources, including x-ray sources
  • Explore non-linear optical phenomena and their applications in wavelength generation
  • Study interference patterns produced by coherent light sources in detail
  • Investigate the design and functionality of advanced laser systems, including potential applications in high-frequency lasers
Physicists, optical engineers, and anyone interested in the principles of wave behavior in electromagnetic radiation, particularly in the context of lasers and interference patterns.
mjasin
I am familiar with the idea of amplitude increases that can be produced by waves that are "in phase". I can imagine this easily with sound or water. I have 2 questions with regard to EM radiation:
1) Do the same principles apply with light/EM radiation? What does "in phase" mean on a practical level for say visible light?
2) If two light/EM sources are put at right angles to each other such that the beams intersect, what sort of interactions/amplifications might you get?
I realize these may be huge questions, so feel free to tell me to find a physics prof to sit down for coffee with. :)
THanks
Science news on Phys.org
Absolutely, bright spots on an interferance pattern are points where the light from multiple sources are in phase.
If you take two coherent light sources, you will get an interferance pattern if you intersect them. If you intersect two incoherent sources, you will just get a spot of higher intensity (more correctly, irradiance) where the beams intersect.
I should point out that increasing irradiance in this fashion is not regarded as amplification.
Claude.
Thanks for the response. Your answers have created more questions for me.
1) Does the principle of coherence apply to sources other than lasers? Could you have an x-ray source that emits coherent xrays?
2) Does the intersection of two non-coherent sources produce altered wavelengths? Or, is the irradiance a simple additive phenomenon?
Thanks again!
1. Coherence applies to any coherent e/m source. Lasers are but one example of a coherent source. I'm not sure if there are coherent x-ray sources available, perhaps another forum member may be able to answer that.
2. Irradiance is by and large an additive phenomenon, although there are special cases where it may not be, for example, in optically non-linear media.
Non-linear effects can cause new wavelengths to be generated, although in order for this to happen, the two beams are typically coaxial, rather than perpendicular to one another.
For the vast majority of cases though, particularly for low powers, no new wavelengths will be generated.
Claude.
Wasn't that idiot Bush trying to use frequency-shifting of an ultraviolet laser after coherence was obtained, for deployment in the Star Wars project? I know that the programme as a whole was a joke, but that approach seemed to show some promise for high-frequency lasers.
As a side note, I needed a gamma laser for my book. That's not exactly attainable, of course, since gamma won't bounce. My approach, which I would love to have some criticism of, was to build a quartz ring with 2 liquid crystal windows of equal refractive index to the quartz replacing 2 facets. One was open to a tube of neon 21, which in turn was exposed to a U-238 pile. That should result in gamma photons of somewhat over 1.6GEv, if I read things correctly. Although gamma can't be reflected, it will refract in a quartz lattice. My idea was to keep pumping photons into the ring in the same direction until you have enough to cause some damage (ie: synchrotron the **** out of it), then polarize the second window to let it out. Steering and focusing were to be achieved by electrostatic deflection plates.
(I can see Russ having a tonne of fun with this.)
At least down to 80nm is achieved:
http://www-hasylab.desy.de/facility/fel/main.htm
An 0.1nm XFEL is planned to start running in 2012 at DESY:
http://xfel.desy.de/technicalinformation/photonbeamparameter/index_eng.html
Perhaps, but I do not readily see how coherence is achieved in this scheme.
That's why I don't call it a laser. I was hoping that the energy density might be high enough just with focusing.
In that case, yes, it is possible, but how "high" you go is dependent on material constraints. And those constraints are extremely difficult to deal with.
Yeah, I hadn't thought of that. I don't imagine that optically matching the LC windows to the quartz would be a tonne of fun either. Oh well... it's just an SF novel. :rolleyes:
  • · Replies 21 ·
  • · Replies 65 ·
