Measuring Wavelength of Photons: Precision & Variation
  • Context: Graduate
  • Thread starter Thread starter liroj
    Photons Wavelength
The discussion centers on the precision of measuring the wavelength of photons, emphasizing that there is no theoretical limit to how small a change in wavelength can be measured. It is established that wavelength is not quantized, as evidenced by phenomena like the Doppler effect. The precision of measurements is fundamentally limited by the signal-to-noise ratio and the energy available to the measuring system. Techniques such as using spectrometers and laser light interference are highlighted as effective methods for achieving high measurement accuracy.
  • Understanding of photon behavior and properties
  • Familiarity with the Doppler effect in light
  • Knowledge of the Heisenberg Uncertainty Principle (HUP)
  • Experience with spectrometry and interference patterns
  • Research advanced techniques in spectrometry for wavelength measurement
  • Explore the implications of the Heisenberg Uncertainty Principle on photon measurements
  • Study the relationship between photon energy and wavelength using E=hf
  • Investigate the concept of Planck length and its relevance in quantum physics
Physicists, optical engineers, and researchers in quantum mechanics who are interested in the measurement and properties of photons and their wavelengths.
  • #31
It also depends on what type of measurement you are happy with. In a Cs atomic clock we know the frequency (and since we are in a high vacuum the wavelength) to within 1 part in 10^15 and in a good optical clock (using photons of e.g. 700 nm) 1 part in in 10^18.
This is of course an "indirect" measurement of the wavelength
Science news on Phys.org
  • #32
I feel that the original question had two components and the arguments here tend to mix them up:
liroj said:
How precise can a wavelength of photons be measured
liroj said:
and how much can it vary?
... is there a point where there is no variation anymore - something like a "quantum" of wavelength?
The answer to the question of whether photon wavelengths can be infinitessimally different in wavelengths or are discretely quantized is that they are NOT quantized in wavelengths, but can be ANY wavelength. The argument from the doppler shift is particularly compelling IMO.
The answer to how precisely wavelength can be measured slips into an uncertainty problem. And a technological problem.
But I think the question was primarily if wavelength is quantized, and the measurement issues from uncertainty were a tangential matter.
On that tangential issue, since a photon has momentum, and an atom is generally 0.1 nm or larger, doesn't that imply the wavelength certainty could never be measured beyond about 0.01 nm? (I'm reasoning that p=h/lambda and (delta-p)*(delta-x)=h/4pi ... so if delta-x is the width of an atom, delta-p leads to a delta-lambda of 1/4pi).
  • #33
  • #34
They did go to a fair amount of effort. I also thought it interesting and couldn't find any flaw in their setup...but this is tricky stuff, mostly beyond my rapidly decreasing attention span.
  • #35
hutchphd said:
There are some folks who claim otherwise:
I find that sort of article very disturbing because it suggests that you could take the idea much further and that could upset a lot of basic principles. Another of those trapdoors in Physics.
  • #36
EnSlavingBlair said:
Potentially. There's something called a Planck length that could be the limiting lower size of anything in the Universe. The problem is it's not something we're near being able to test, so it's very hypothetical. You can read more about it and what the consequences of it could be here https://newt.phys.unsw.edu.au/einsteinlight/jw/module6_Planck.htm
It also covers a bit if the other part of your question, but many before me have already addressed that.
Hope that helps
It helped me---I write sci fi and this site -above was excellently explained. Thank you
  • · Replies 88 ·
25K
  • · Replies 24 ·
  • · Replies 23 ·
10K
  • · Replies 26 ·
