earlofwessex said:
thanks both of you
i've not come across z, so i can't really follow this. you seem to be saying that vacuum energy is just a different way of looking at redshift due to expansion. hit me with the symmetry argument, if you don't mind, it might help to clear things up. in the mean time i'll go and look up z.
Z is the variable used to describe the redshift:
\lambda' = (1 + z)\lambda
Here \lambda' is the wavelength after the redshift is applied, with \lambda being the wavelength when the photon was emitted.
earlofwessex said:
is vacuum energy density not a constant? what other conditions need to be specified?
sorry if that's a stupid question
Well, we don't yet know where the vacuum energy comes from, so we can't say. It's basically constant within our own visible universe, but this doesn't mean it isn't different elsewhere. If we're going to take a hypothetical scenario, there's no a priori reason why we should assume that the cosmological constant should be the same as what we measure in our observable region.
Anyway, that said, in order to get the behavior of a region of the universe, you have to specify the total energy density for each component of the universe (e.g. radiation, normal matter, dark matter, vacuum energy). Then you have to specify an expansion rate at a particular time (such as the current rate of expansion). Once you've done this, the universe follows the first Friedmann equation:
H^2(a) = \frac{8 \pi G}{3} \rho - \frac{k c^2}{a^2}
Here \rho is the total energy density of the universe, including any vacuum energy, and k is the spatial curvature. If we know the expansion rate at a given time, we can calculate the curvature. Basically, if you have a universe with low energy density and a fast expansion rate, then you have a large negative curvature (open universe) that will tend to expand forever. If, by contrast, you have a high energy density and a low expansion rate, then you have a large positive curvature (closed universe) that tends to recollapse back on itself under its own gravity. If you have a lot of vacuum energy (positive or negative), this can change things, but I think that this gives a nice intuitive picture of how it works.
Now, once you have this equation, you need to know how the various components of the universe scale in energy density with expansion. That is, the parameter that defines the expansion is a. If this parameter doubles (meaning things will be, on average, twice as far apart), how does the energy density change?
With normal matter, this is easy: increase the distance by a factor of a, and you increase the volume by a factor of a^3. The energy per bit of normal matter stays about the same, but now occupies a much larger volume, meaning the energy density is reduced by a factor of 1/a^3.
Radiation is very similar: increase the scale factor, and you have the same number of photons in a larger region of space. So the number of photons also drops by 1/a^3. However, the photons are also redshifted by the expansion, such that the energy per photon is reduced by a factor of 1/a, and so the photon energy density scales as 1/a^4.
Vacuum energy keeps the same density with time, so that remains unchanged.
Did this help?
earlofwessex said:
can i say,
take a space big enough to contain a horizon, and completely empty, which obeys all the laws that our universe does. the space is neither expanding nor contracting at t=0
does one of those laws dictate that it expands? or is that a meaningless question, as there's nothing there to move?
Well, yeah, it would be pretty much meaningless if there's nothing there.
