Waves on a string fixed at both ends
  • Context: Undergrad
  • Thread starter Thread starter cavis
    String Waves
The discussion revolves around the behavior of waves and standing waves on a string fixed at both ends, particularly focusing on the effects of plucking a guitar string and the generation of various frequencies. Participants explore concepts related to Fourier series, harmonic frequencies, and the impact of damping on wave propagation.
  • Some participants propose that plucking a string excites multiple standing wave frequencies simultaneously, including the fundamental and higher harmonics.
  • There is a question about whether frequencies other than the standing wave frequencies can be generated by the initial pluck, with some suggesting that these frequencies may die out due to damping.
  • One participant describes the initial shape of the string when plucked as a triangle, which can be represented as a sum over harmonics.
  • Another participant discusses the behavior of a string when driven at non-harmonic frequencies, suggesting that any periodic function can be represented as a sum of harmonic standing waves.
  • Concerns are raised about the coupling of energy into frequencies not consistent with boundary conditions, emphasizing that only the fundamental and overtones can be excited.
  • Some participants note that the perception of pitch from a string being plucked is primarily determined by the fundamental frequency and the harmonics present.
Participants generally agree on the role of the fundamental and overtones in wave generation, but there are competing views regarding the excitation of non-harmonic frequencies and the effects of damping. The discussion remains unresolved on certain aspects, particularly regarding the behavior of the string under various conditions.
Participants mention limitations related to damping and boundary conditions, which affect the frequencies that can be excited and the persistence of certain waveforms. There is also a reference to the physical realities of experiments that may introduce additional complexities.
cavis
Hi all,
I've got a question about waves and standing waves on a string fixed at both ends. I understand why only certain discrete wavelengths / frequencies are allowed to generate standing waves on a string such as a guitar string. My question pertains to understand what happens when a guitar string is plucked.
At the instant the string is plucked, the instantaneous shape of the string does not resemble any of the standing wave modes, but I understand that the pluck essentially sets the string vibrating with several modes at once... the fundamental and the higher harmonics. I guess I'm trying to visualize the shape of the string when plucked as being the sum of a Fourier series made up by adding up essentially an infinite number of standing wave frequencies.
My questions are:
1) Is my description of exciting a number of different standing wave frequencies at once correct?
2) Can frequencies other than the set standing wave frequencies be generated by the initial pluck? Do these other frequencies rapidly die out (which is why they seem to be seldom mentioned at all in descriptions in introductory texts), or are they never excited at all? If they're never excited at all, why is that the case?
I guess the main thing I'm struggling with is how a seemingly arbitrary string shape generated by the pluck can be represented just by the standing wave patterns.
Cheers,
Chris.
cavis said:
Hi all,
My questions are:
Yes.
If you pluck a guitar string from the middle, the shape of the string is a triangle. The triangle shape can be represented as a sum over harmonics.
The extra harmonics typically die out - this is mainly due to damping, but the sub-harmonics in a note are what gives different instruments their characteristic sound. Some sub-harmonics are reinforced by the geometry of the instrument - compare an (acoustic) Bass guitar with a regular guitar and with a Ukelele.
Perhaps a more general idea is needed?
1. If you distort a spring at one end, creating a pulse, you know the pulse travels to the other end, inverts, then travels back (fixed ends) right?
2. So, if you distort the far end instead, the pulse travels to the near-end, inverts, then goes back. So far so good.
3. But what happens if you were to make a pulse exactly in the center of the spring?
Which way does it go?
4. The answer is that 1 & 2 are incorrect. In each case the pulse splits in half - each half going in opposite directions. If you look closely at the initial two cases you'll see that each pulse is being followed by an inverted version.
5. when you pluck a string, you make a big triangle pulse stretching the whole length of the string. You should be able to split that into two equal sized pulses going in opposite directions, inverting a the ends, and then reinforcing appropriately to make a funny looking standing wave ... do it.
With no losses, the standing wave starts out as an upright triangle - the top gets flat - the flat part spreads but the slope parts keeps it's shape - until it is totally flat and starts building an inverted triangle.
With losses, some parts of the string lose energy faster than others - the shape that is sustained will be sinusoidal ... in the math, we see the Fourier transform lose the higher frequency terms.
Thank you for the response, Simon. It helps a lot. May I ask another quick question?
A classic demo involving waves on a string is to attach a vibrator to one end of the string whose other end is a fixed end. The vibrator oscillates up and down with a very small amplitude (so this end of the string is effectively a node also) and can excite large standing waves in the string if the vibrator frequency is the same as a harmonic frequency for the string.
What I'm curious about is the case where the vibrator frequency is not equal to a standing wave frequency... here the string does not vibrate up and down in a nice standing wave pattern. But, if I understand Fourier's theorem correctly, the sinusoidal waves that are being generated on the string by the vibrator can still be visualized as a sum of the harmonic standing waves on the string since any periodic function on the string should be representable as the sum of the harmonics even though the frequency of the sinusoidal waves being generated is not itself a harmonic frequency. Is this correct?
I also understand that when we hear the sound of a string being plucked our ear interprets the sound's pitch as essentially the fundamental frequency plus a bunch of harmonics which determine the tone. If we were to consider the case describe above with a string deliberately excited at a non-harmonic frequency, would we still perceive the pitch of the sound emanating from the string as being the fundamental for the string?
Thanks again for your response!
Chris.
Even for a lossless string, the only modes that can be exited will be the fundamental and overtones. Energy just wouldn't be coupled into any other frequencies due to the boundary conditions.
@sophiecentaur: yeh - I wouldn't want anyone to think I meant that any frequencies not consistent with the boundary conditions could be excited. I mean only that the fundamental + overtones so set form a basis and any waveform on the string can be represented as a linear superposition of them. The components that are not otherwise reinforced die out - mainly due to damping. I found a demo:
... I tried to find one with a less lossy string, plucked dead center, but no luck.
However, it does illustrate a lot of what I was talking about and can be used as a clarification.
If you drive a string like that, you can get a node quite close to the multivibrator - the effective length of the string is to that point (as far as your-level calculations are concerned.)
Start at resonance for the fundamental - you get a high amplitude standing wave.
As you increase the frequency of the multivibrator the amplitude of this wave decreases - after a while there is very little excitation at all... keep increasing the frequency and the next harmonic appears and increases in amplitude.
There are other "natural modes" due to the physical realities of the experiment. See discussion: http://www.colorado.edu/physics/phys4830/phys4830_fa01/lab/n1106.htm for examples.
You can also see low-amplitude traveling waves at the in-between frequencies. In demos, the amplitude of the multivibrator is usually chosen to be small so that the traveling waves just make the string look a bit blurry to the eye.
There are a bunch of video demos on youtube that show all this - go look.
You can do the experiment and listen to it and see.
When you drive the string you normally hear the driving frequency as a hum.
These are really the sorts of things you just have to experience to "get" so next time you have the opportunity - take it.
  • · Replies 21 ·
  • · Replies 19 ·
  • · Replies 101 ·
47K
