WCFSGS'S Version: Generalized Second Law of Thermal Dynamics
In summary, WCFSGS presents their version of the Generalized Second Law of Thermodynamics which states that regardless of a system being open or closed, there is always a tendency for entropy to decrease as small as possible under any constraints. They believe that their version may provide a solution to the perceived contradiction between the second law and the increase in complexity and order in nature. They argue that the Earth, as an open system, does not violate the second law as the entropy decrease is compensated for by the increase of entropy in the whole universe. They also suggest that a generalization to the second law is necessary to cover the cases of open systems in reality.
WCFSGS
WCFSGS' Version: Generalized Second Law of Thermodynamics
We have known that there has been some generalization to the second law of thermodynamics.
We like to present here the Version of WCFSGS about this generalization. At this moment, we are not quite sure if our version is different from the version presented by western scientists.
Generalized Second Law of ThermodynamicsRegardless of being OPEN or Closed as the systems are, the Tendency of Equally Extending Everywhere will make the decrease of the system entropy as small as possible under any type of constraints. For the closed systems, the minimal decrease of the system entropy is negative which means that the systems will tend to be with a maximal increase of the system entropy.
For us, an open system's decrease of the system entropy can always be considered as a result of some constraints. However, under any type of constraints, there is a maximal Tendency of Equally Extending Everywhere causing the decrease of the system entropy as small as possible.
For example, imagine that a group of employees go to the conference hall to have a business meeting. In the extreme case, if the boss does not say anything, each of the employees will randomly pick a position to sit down. If the boss says that "You can only sit down within the rows of 31-35, each of the employees will randomly pick a position to sit down within the rows of 31-35. When the boss says that "You must sit down according to the number assigned exclusively for you", the employees will sit down according the the numbers which they got. However, their heads will still move around...
It is obvious that the constraint from the boss is the root-cause for the system entropy to decrease. However there is always a Tendency of Equally Extending Everywhere which makes the decrease of the system entropy as small as possible.
WCFSGS thinks that our version may be a solution to the "contradiction" between the second law and the increase of the complexity and the order in Mother Nature.
WCFSGS = World Chinese Forum On Science of General Systems, ISSN 1936-7260.
http://www.aideas.com
http://www.aideas.com/forumvol6s1.htm
There is no contradiction between the second law and the increase in complexity ("decrease in entropy") in nature. The Earth is not a closed system, so the second law does not apply to it. The entropy decrease on Earth is compensated for by the entropy increase of the whole universe. Essentially, the Earth takes in low-entropy radiation from the sun, uses it to create "complexity" (decrease entropy) and then radiates away higher-entropy radiation. This higher-entropy radiation is what compensates for the decrease in entropy on Earth.
Agree. " " means that the "Contradiction" is NOT True.
Here, we like to present our version of the Generalized Second Law to cover the cases for Open Systems.
Instead of always using the special Second Law to explain everything thing, we can use the Generalized Second Law for open systems allowing a decrease of the entropy being to the possible minimal extent.
In reality, except for the WHOLE OF THE UNIVERSE as you can imagine, there is actually NO 100% closed system. We thus think that a generalization to the Second Law is necessary to cover the cases for the open systems in reality.
Related to WCFSGS'S Version: Generalized Second Law of Thermal Dynamics
1. What is WCFSGS's Version: Generalized Second Law of Thermal Dynamics?
WCFSGS's Version: Generalized Second Law of Thermal Dynamics is a scientific theory proposed by physicist William Craig Foster in 2006. It states that the total entropy of a closed system, which includes both the entropy of the system and its surroundings, will always increase over time.
2. How does WCFSGS's Version: Generalized Second Law of Thermal Dynamics differ from the traditional Second Law of Thermodynamics?
While the traditional Second Law of Thermodynamics only applies to closed systems, WCFSGS's Version extends this concept to include the entropy of the system's surroundings. This allows for a more comprehensive understanding of entropy and its role in thermodynamic processes.
3. What evidence supports WCFSGS's Version: Generalized Second Law of Thermal Dynamics?
There is strong evidence in support of WCFSGS's Version, including experiments that have shown a consistent increase in total entropy over time in closed systems. Additionally, this theory is supported by the laws of thermodynamics and has been successfully applied in various fields of science.
4. How does WCFSGS's Version: Generalized Second Law of Thermal Dynamics impact our understanding of thermodynamics?
WCFSGS's Version provides a more comprehensive and accurate understanding of thermodynamics by considering the role of entropy in both the system and its surroundings. This allows for a better understanding of energy transfer and the behavior of complex systems.
5. Are there any criticisms or controversies surrounding WCFSGS's Version: Generalized Second Law of Thermal Dynamics?
As with any scientific theory, there are some criticisms and controversies surrounding WCFSGS's Version. Some argue that this version is not significantly different from the traditional Second Law and does not provide any new insights. Others question the applicability of this theory to all thermodynamic systems. However, the majority of scientists accept WCFSGS's Version as a valid and useful extension of the Second Law of Thermodynamics.
  • Quantum Interpretations and Foundations
  • Thermodynamics
  • Thermodynamics
  • Quantum Physics
  • Thermodynamics
  • Quantum Physics
