Weak principle of equivalence (Galileo, Newton)
The discussion revolves around the weak principle of equivalence as articulated by Galileo and Newton, particularly focusing on the relationship between gravitational force and inertial force during free fall. Participants explore whether gravitational force equals inertial force in this context and the implications for the concepts of gravitational and inertial mass, as well as the relevance of general relativity (GR).
  • Some participants question whether a body in free fall is affected by inertial force due to gravitational acceleration, specifically asking if gravitational force equals inertial force (Fg=Fi).
  • It is noted that inertia is synonymous with inertial mass, and that inertia itself is not a force.
  • One participant asserts that gravitational mass equals inertial mass, leading to the conclusion that in free fall, gravitational force and inertial force can be equated, but expresses uncertainty about the implications of this view.
  • Another participant argues that inertial forces arise from using a non-inertial reference frame, suggesting that the discussion requires clarification on the reference frame being used.
  • A later reply challenges the notion of a "force of inertia," stating that it complicates the understanding of motion and that Newton's second law (f=ma) adequately describes the relationship without needing to invoke additional forces.
  • Some participants express a view that the full understanding of these concepts, particularly regarding gravity, is found within the framework of general relativity.
Participants exhibit a mix of agreement and disagreement. While there is some consensus on the definitions of gravitational and inertial mass, the interpretation of forces in free fall and the role of inertial frames remains contested, with no clear resolution on the implications of these concepts.
The discussion highlights limitations in understanding the relationship between forces in different reference frames and the potential confusion surrounding the concept of inertial forces. There are unresolved questions regarding the implications of these ideas within classical physics and general relativity.
qnt200
TL;DR
Does the force of inertia act on the body during free fall, according to the weak principle of equivalence (Galileo, Newton)?
Many tutorials that explain the weak principle of equivalence (Galileo, Newton) do not clearly state whether the body is affected by the force of inertia during free fall as a result of the gravitational acceleration of the body. In other words, the question is whether, during the free fall of a body in a gravitational field, gravitational force equals inertial force (Fg=Fi).
Is this incompatible with the concept of two masses (gravity and inertial mass)? What is GR's opinion on it?
There is mass, gravitational and inertial. Inertia is another name for inertial mass.
Inertia is not a force.
Thank you for explaining. It raises a few more questions for me about the logic of bodies in free-fall:
It is known that gravitational mass = inertial mass (established with enormous precision). That is why we can talk about only one mass. Therefore m = mg = mi. In free fall, mg = ma, i.e., g = a. The product of ma acts as inertia on the body, slowing it down during free fall so that it does not instantly reach the speed of light.
I think it is irrelevant whether the product of mass and acceleration is called a force.
I don't know how correct this attitude is?
This doesn’t make sense. Inertial forces are not a result of acceleration. Inertial forces are a result of using a non-inertial reference frame. Sometimes non-inertial frames are called accelerating frames, but an accelerating frame is a different concept than acceleration.
If you want to ask about inertial forces then you must specify the non-inertial reference frame you are using.
It is difficult to follow what you are saying here. It seems to indicate that you are understanding things incorrectly (or at least not in the standard way).
Apparently you have this idea that if we exert a force on an object then, were it not for the object's inertia, that object would fly away at the speed of light. That is a somewhat reasonable intuition.
To be picky, if we stay within the Newtonian framework, there is nothing special about the speed of light. A massless object subject to a finite force would be pushed away with an undefined speed. We might think of that speed as infinite, but from a mathematician's point of view, "undefined" is more correct. A mathematically inclined physicist would likely say that you cannot exert a finite force on a massless object.
But never mind that. Set the speed of light to one side.
You want to rescue us from having the object move off at an undefined velocity by conjuring up a counter-force called the "force of inertia". So we have this original real force f=ma pushing the object away and this magical counter-force pushing back. But hold on a minute... if we have equal and opposite forces then the object should not move at all. Eppur si muove.
We see real objects subject to real forces move all the time. So this way of thinking about the "force of inertia" cannot be entirely correct.
The standard way of thinking about this is to stick to inertial frames. You have an interaction force ##f## and an object of mass ##m## moves off with an acceleration ##a## when acted upon by that force. End of story.
We do not wave our hands and conjure up a force to explain the resulting motion. We already have the original force ##f## that explains the motion and a law of motion (##f=ma##) that quantifies the result. There is no need for anything more. The property that we call "inertia" is already encapsulated in Newton's second law.One can rescue the idea of an "inertial force" associated with an object's mass by adopting a non-inertial frame. But others such as @Dale are happily explaining that part.
Dale, jbriggs444
Thank you for your interesting answers and guidelines indicating to me the scope of classical physics, i.e., the inertial frame of reference. F=ma is only valid in inertial frames of reference. It is actually clear to me that the full answers, especially regarding gravity, are found within GR.In addition to other things, you pointed out a very interesting question that I have been thinking about for a long time:
  • · Replies 36 ·
  • · Replies 44 ·
  • · Replies 32 ·
  • · Replies 48 ·
  • · Replies 17 ·
