Webpage title: How to Find the Area Bounded by Curves on a Given Interval
  • Context: Undergrad
  • Thread starter Thread starter noboost4you
    Area Bounded Curves
The discussion revolves around finding the area bounded by the curves f(x) = x^2 + 2 and g(x) = 4 - x^2 on the interval [-2, 2]. Participants explore the interpretation of the problem, the setup of integrals, and the handling of areas that may be negative due to the nature of the functions involved.
  • Homework-related
  • One participant expresses confusion about the integral setup, noting that their calculation resulted in a negative area, which is not possible.
  • Another participant suggests that the problem may be ambiguous and questions whether the instructor made an error in the problem statement.
  • Some participants propose that the area should be calculated by considering multiple integrals across different segments of the interval, particularly where the curves intersect.
  • A later reply emphasizes the importance of taking the absolute value of the integrals to ensure the area is non-negative.
  • Another participant suggests that the area should be divided into three separate integrals to account for the different regions bounded by the curves.
  • One participant confirms that their final solution involved three separate integrals, leading to a positive area result.
Participants do not reach a consensus on the interpretation of the problem or the correct approach to solving it. Multiple competing views on how to handle the area calculations remain present throughout the discussion.
There are unresolved assumptions regarding the interpretation of the problem statement and the necessity of including areas outside the intersection points of the curves. The discussion also reflects uncertainty about the correct mathematical approach to take.
Students grappling with integral calculus, particularly in the context of finding areas between curves, may find the varied perspectives and approaches discussed here helpful.
noboost4you
This is the problem: find the area of the region bounded by the curves f(x) = x^2 + 2 and g(x) = 4 - x^2 on the interval [-2,2]
I did the whole integral from -2 to 2 with (4-x^2) - (x^2 + 2) dx because the graph of g(x) is on top between the region bounded. But from my drawing, the points where the curves meet and shaded in the area is between -1 and 1. What am I doing wrong?
My answer came to be -8/3 and area can't be negative. Any suggestions?
Thanks
It's a of an ambiguous question ... see my attached image. Check that question for typo's, just in case.
no typos here. he wrote this problem on the board today, maybe he has it wrong?? the question never says anything about the area under the curves, just the region bounded by the curves on the interval [-2,2]. maybe i need to draw imaginary vertical lines at -2 and 2 and include that area as well as under the curves?
i'm lost and it's only the 2nd day of class...oohh, i can't wait until the 3rd day
Don't worry. I'm sure if you pointed out the confusion, he'll tell what he meant.
So as it stands right now, that equation is impossible to answer? Correct?
I wouldn't say it was impossible, just ambiguous as to exactly what was being asked. Since the problem asks for "area bounded by the curves between -2 and 2, I would say it must be:
∫-2-1((x2+2)-(4-x2)dx+ ∫-11((4-x2)-(x2+2))dx+ ∫12((x2+2)-(4-x2))dx.
That is, reverse the subtraction on the two ends where the curves are reversed.
The area bounded by [tex]f(x)[/tex] and [tex]g(x)[/tex] where [tex]a \le x \le b[/tex] is given by
[tex] \int_a^b \left|f(x)-g(x)\right|\mathrm{d}x[/tex]
Consider the integral
[tex] \int_{\pi}^{2\pi} \sin x \mathrm{d}x[/tex]
The graph is below the x-axis, so the value will be negative. An area can't be negative, so you just take the absolute value of it.
Regards,
Nille
What I am guessing he wanted you to do is to include the two areas on each side of the curves...So include the area from -2 to -1 from -1 to 1 and from 1 to 2... Thats what I prob would do...So then you would have three separate integrals 2 of which should be the same area...and one different one in the middle..
Just my 2 cents...
Yes, the answer included 3 separate integrals. The final solution came to 8. Thanks to all who helped out. I really appreciate it.
No problemo my friend...I though it would include 3 separate integrals otherwise he wouldn't have given you intervals...If he didn't give u intervals then you would only have one integral from -1 to 1...But since he told you that you have interval from -2 to 2,then you would have to sketch the graph, see how it looks, and then come up with the fact that there is actually 3 separate areas which need to be added...
I am glad you solved your problem. :)
  • · Replies 20 ·
  • · Replies 24 ·
