Solve Wedge-Block Problem: Velocity of Block
  • Thread starter Thread starter AnwaarKhalid
    Block Wedge
The discussion revolves around calculating the velocity of a triangular block when a smaller block slides down its surface. The user applies momentum conservation and energy conservation principles, leading to a derived equation for the velocity of the triangular block. However, confusion arises regarding the inclusion of the angle of inclination in the calculations. The user seeks clarification on the role of the angle and the definition of variables in their equations. The conversation emphasizes the importance of correctly integrating the angle into the solution for accurate results.
AnwaarKhalid
A block of mass m is placed on a triangular block of mass M which in turn is placed on a horizontal surface. Assuming friction less surfaces find the velocity of the triangular block when the smaller block reaches the bottom end.The angle of inclination of the plane is 'theta'.
my approach to the problem...when the small block reaches the bottom...momentum in x direction is conserved...mu=Mv...where u and v are absolute velocities of the smallerb block bigger block respectivelyapplying conservation of energy...mgh=1/2mu(squared)+1/2mV(squared)solving the above two equations...V=m/M(root of){2Mgh/M+m}but the answer is complex in terms of angle...please explain where I am wrong
I do not see the angle in your derivation. What exactly is your u?
  • · Replies 92 ·
10K
  • · Replies 18 ·
  • · Replies 38 ·
