Weight of ball/water/cylinder system as the ball falls
The discussion centers on the dynamics of a steel ball dropped into a water-filled cylinder on a scale. The consensus is that the weight on the scale remains constant once the ball is fully submerged, as the total weight of the system (ball, water, and cylinder) acts downward throughout the process. The forces at play include gravitational force and buoyant force, which balance out when the ball is submerged. The normal force from the bottom of the cylinder does not affect the overall weight measured by the scale.
  • Understanding of Newton's Second Law (F=MA)
  • Knowledge of buoyant force and water displacement
  • Familiarity with the concept of normal force in physics
  • Basic principles of fluid mechanics
  • Study the principles of buoyancy and Archimedes' principle
  • Explore the relationship between force, mass, and acceleration in different contexts
  • Investigate the effects of submerged objects on fluid pressure
  • Learn about the dynamics of systems involving multiple forces
Students studying physics, particularly those focusing on mechanics and fluid dynamics, as well as educators looking for practical examples of force interactions in a fluid system.
jordanstreet
So you have a cylinder filled with water sitting on a scale. You take a steel ball and drop it in the water. So does the weight on the scale:
1)Immediately change and stay constant including when the ball comes to rest on the bottom
2)Increase immediately when the ball is fully submerged and then increase again when it hits the bottom.
3)Some thing else?
F=MA
Fb=Weight of water displaced
I'm thinking that the weight stays constant the whole once its fully submerged.
Try to think in terms of force acting on the ball.
The ball is moving downward, and then when it hits the water, what happens?
The ball is moving downward in the water, and then when it strikes the bottom, what happens?
The ball starts fully submerged.
In terms of the cylinder system the total weight of the ball + water + cylinder acts downward the whole time. Does the normal force from the bottom of the cylinder change when the ball hits it? If so wouldn't that change the weight of the whole system since gravity and buoyant force are the same the whole time for the ball?
  • · Replies 25 ·
  • · Replies 31 ·
