Weight of barge on a bridge canal/acqueduct
  • Thread starter Thread starter bigboss
    Bridge Weight
The discussion centers on the physics of a heavily loaded barge crossing a canal bridge in medieval England. Participants concluded that the force on the bridge remains unchanged when the barge passes over it, as the total mass of the system (water plus barge) does not change. The barge displaces an equal volume of water, and the buoyancy force acting on the barge balances its weight, resulting in no net change in force on the bridge. The consensus is that the correct answer to the posed question is option A.
  • Understanding of buoyancy principles in fluid mechanics
  • Knowledge of force and weight relationships in physics
  • Familiarity with the concept of displacement in fluids
  • Basic comprehension of Newton's third law of motion
  • Study the principles of buoyancy and Archimedes' principle
  • Explore the relationship between mass, weight, and force in physics
  • Learn about fluid dynamics and the behavior of displaced fluids
  • Investigate real-world applications of these principles in engineering structures
Students of physics, engineers involved in structural design, and anyone interested in the mechanics of fluid systems and buoyancy effects.
bigboss
In England in the Middle Ages an extensive system of canals was used for transportation. Some of these canals crossed over canyons by flowing over bridges (viaducts). Suppose that a heavily loaded barge crossed over such a waterway bridge.
A)The force on the bridge would not change when the barge passed over.
B)The force on the barge would become less because some water would be squeezed off of the bridge.
C)The force downward on the bridge would increase because of the added weight of the barge.
D)The force on the bridge would become less because of the buoyancy effect of the water on the barge.
E)Whether or not the force on the bridge would increase or decrease would depend on whether the water was flowing or stationary.
Fb= mg=pvg
i believe it is C, but i am not very sure
The barge displaces an equal mass of water, i.e. the mass does not change.
The 18century is middle ages?
so if the mass does not change, what does that mean?
"Displaces" doesn't necessarily mean, "causes to spill out of the aqueduct," does it? What if there is more than enough extra room?
Also, doesn't the barge displace an equal volume (not mass) of water i.e. equal to the volume of the portion of the barge that is submerged?
Does the bow wave add mass?
""Displaces" doesn't necessarily mean, "causes to spill out of the aqueduct," does it? What if there is more than enough extra room?"
Because of choice B (...because some water would be squeezed off of the bridge), I think the question assumes there's no extra room. That's ridiculously unrealistic, of course, but so are most physics problems.
"Also, doesn't the barge displace an equal volume (not mass) of water i.e. equal to the volume of the portion of the barge that is submerged?"
Both are true. If the barge is floating, it displaces a volume of water equal to the volume of part of the object that's submerged, but if that volume is filled with water, its weight would equal that of the barge. If this weren't the case, gravity and buoyancy wouldn't balance, and the barge would move upwards or downwards until they do.
i am still not understanding this, what would be the answer?
The Falkirk Wheel in Scotland for extra credit.
http://cache.gizmodo.com/gadgets/images/falkirk_wheel.jpg
Right. I knew that. :blushing:
I think this is a badly worded problem though. If we're supposed to make certain assumptions when answering it, then that should be stated explicitly.
Initially the aqueduct contains a certain mass of water which has a certain weight. This weight is supported by the bridge.
If we go with Astronuc on this one, then after the barge starts traversing the aqueduct, the total mass of stuff in the aqueduct (water + barge) DOESN'T change compared to what it was initially. If the total mass of stuff in the aqueduct is the same, then what about its weight compared to before?
then the weight would be the same
mass doesn't change therefore weight doesn't change.
[/URL] That's very cool.
therefore, force does not change? A?
"therefore, force does not change? A? "
With the assumption that any water the barge displaces spills out of the aqueduct, yes.
When there is no barge on the canal, the weight on the bridge is the weight of the water in the canal. When the barge enters the canal, buoyancy act on the barge, which is equal to the loss weight of the barge. Equal and opposite reaction of the barge act on the bridge through water. So the choice is C.
If the presumption is that the water level is invariant, because the barge is already in the water before entering the water bridge, as well as after, then the mass borne by the bridge looks also to be invariant, (as Astronuc, ideasrule, et al have pointed out). The buoyancy that supports the boat, the displaced water, accounts for the whole weight of the boat. So yes the barge bears down on the water and the water on the bridge, but there is less water bearing down on the bridge that nature has conveniently managed to make identical to the weight of the barge in floating it in the first place.
I'd say where any additional weight is added is at the point that the boat initially enters the bodies of water on either side of the bridge, and the water level minutely adjusts itself over all the water from that point onward.
no, no. The extra water can go anywhere. It can spill out of the canal, or the presence of the boat forces the water up and down the canal, as long as the level of the water is the same.
And Yes, the force doesn't change. Weight is a force.
  • · Replies 29 ·
10K
11K
