Weights and pulleys in harmonic motion
43 replies · 5K views
Karol
No friction. m3=5m, m2=12m, m1=3m
Prove that the system's acceleration when it's released is a=0.2g. is it the max acceleration?
Show that the equilibrium point is at x0=0.75L
Show that the kinetic energy of the system is E=mgL
Show that m2 will stop momentarily at ##x_1=\frac{15}{8}L##
Harmonic motion, the force is proportional to the displacement: F=kx
$$\ddot x=\omega^2x=0$$
The initial state:
$$\left\{ \begin{array}{l} m_1g-T=(m_1+m_2)a \\ T=m_2a \end{array}\right.\;\rightarrow a=\frac{3}{27}g=0.11g$$
It's wrong.
In the intermediate state:
m2 accelerates distance x but the rope lengthens by:
The cosine rule:
$$l_1^2=x^2+\frac{L^2}{\sin^2\alpha}-2x \frac{L}{\sin\alpha}\cos\alpha$$
$$\Delta l=\frac{L}{\sin\alpha}-\sqrt{x^2-\frac{2L}{\tan\alpha}x+\frac{L^2}{\sin^2\alpha}}$$
$$\left\{ \begin{array}{l} m_1g-T_1=m_1\ddot x \\ T_1-T_3\cos\alpha=m_2\ddot\Delta l \\ T_3-m_3g=m_3\ddot\Delta l \end{array} \right.$$
It's complicated, Δl and it's derivative and i am afraid it won't get to a second order differential equation.
The initial state:View attachment 88066
It's wrong.
The net force on m1 is m1g-T. And force = mass times acceleration.
$$\left\{ \begin{array}{l} m_1g-T=m_1a \\ T=m_2a \end{array}\right.\;\rightarrow a=\frac{3}{27}g=0.2g$$
What kind of Maths do you use?
Sorry,:
$$\left\{ \begin{array}{l} m_1g-T=m_1a \\ T=m_2a \end{array}\right.\;\rightarrow a=\frac{3}{15}g=0.2g$$
And it's correct
Can someone please help?
I correct the original set of equations:
$$\left\{ \begin{array}{l} m_1g-T_1=m_1\ddot x \\ T_1-T_3\cos\alpha=m_2\ddot x \\ T_3-m_3g=m_3\ddot\Delta l \end{array} \right.$$
All right, so where is equilibrium?
$$m_1g=m_3g\cdot \cos\alpha\;\rightarrow x=0.75L$$
I tried a simpler relation between x1 and x3 based on Pitagora's formula:
$$x_3=\sqrt{L^2+x^2}-L$$
$$\left\{ \begin{array}{l} m_1g-T_1=m_1\ddot x \\ T_1-T_3\cos\alpha=m_2\ddot x \\ T_3-m_3g=m_3\ddot x_3 \end{array} \right.$$
Still the derivative is complicated, maybe i don't have to derive?
The second derivative of x3 is a bit complicated, but it can be done.
You can find the point where m2 momentarily stops from energy considerations.
I do not understand the question "Show that the kinetic energy of the system is E=mgL" . The kinetic energy changes during the motion. Did you copy the problem correctly?
If the system is released when x = 0 the motion is not SHM, but it can be SHM around the equilibrium point for small displacements. But I do not see any question in the problem that concerns SHM.
Indeed strange but the decrease in potential energy of m1 and 3 at the equilibrium point, at x0 is:
$$x_3=\sqrt{L^2+(0.75L)^2}-L=0.25L$$
$$E=0.75Lm_1g-0.25Lm_3g=gLm$$
I guess the equilibrium point isn't in the middle of the path:
The total energy of E=Lmg must be also at the right end of the path, x is the distance to the right of the equilibrium point x0:
$$Lmg=m_1gx-m_3g\left( \sqrt{L^2+(0.75x)^2}-L \right)$$
$$Lmg=m_1gx-m_3g\left( \sqrt{\frac{25}{16}+\frac{3}{2}Lx+x^2}-L \right)$$
Complicated
How do you know that around the equilibrium point it's SHM without even seeing (or did you see) the solved equation of motion? or is every non-harmonic motion approximately SHM near the equilibrium?
I was also asked if a=0.2g, the acceleration at the start is the maximum and i think yes because x=0 is one the 2 ends of the track m2 makes and at those ends the acceleration is max
Then the question must have been " what is the KE at the equilibrium point". OK.
Karol said:
I guess the equilibrium point isn't in the middle of the path:View attachment 88357
Complicated
Initially you defined x as the displacement of m2 from its initial position, when the string connected to it was vertical. Write the potential energy in terms of that x. It would be much simpler. Square the equation and solve.
I considered the initial potential energy zero, and found the point where it is zero again. In this way, the equation was even simpler.
You can write the potential energy and if it has a minimum, around that minimum the Taylor series of the potential energy has a positive term proportional to the square of the displacement from the equilibrium, like in case of an SHM.
I am not sure, and I did not do it yet. If it was SHM, the magnitude of the acceleration would be the same at both ends. But the other turning point is closer to the equilibrium point.
I suggest to find the turning point and see what forces act and what is the acceleration there.
$$2\cdot Lmg=m_1gx-m_3g\left( \sqrt{L^2+x^2}-L \right)\quad\rightarrow \quad 3x+3L=5\sqrt{L^2+x^2}$$
And the solution is imaginary.
I don't know how to do it, i think i made it in the previous equation since ##2\cdot Lmg=...##
$$E=m_3g\left[ \sqrt{L^2+x^2}-L \right]-m_1gx$$
$$E'=\left[ \frac{m_3x}{\sqrt{L^2+x^2}}-m_1 \right]g$$
Minimum at x=0.75L
The potential energy of SHM is ##E_p=\frac{1}{2}kx^2## and the Taylor series is ##f(x+h)=f(x)+hf'(x)+\frac{h^2}{2}f''(x)##
The first and second terms aren't proportional to the square of the displacement, is it enough that only the third term that is proportional and the whole potential energy will be like in SHM and the whole behavior will be like SHM?
I take ##x_1=\frac{15}{8}L## as the other end, and the forces are:
$$\tan \alpha=\frac{8}{15}$$
$$F=m_3g\cos\alpha-m_1g=2.7mg$$
$$2.7mg=m_2a\quad\rightarrow \quad a=2.3g$$
You do not know at what height were the masses m1 and m3 initially. x1 and x3 are displacement from the initial positions, x1 downward and x3 upward. So what is the change of the potential energy in terms of these displacements?
When the system stops, the whole energy is potential. Initially, the system was in rest. So the potential energy at the point where the system stops is the same as it was initially. The change of potential energy is zero, not 2Lmg.
The equilibrium point is at the minimum of the potential energy. Take the Taylor series around that minimum. At the minimum, f ' =0. And you can choose the potential energy zero at the equilibrium point. So you have only the second-order term in the Taylor expansion.
$$0=m_1gx-m_3g\left( \sqrt{L^2+x^2}-L \right)\quad\rightarrow \quad x=\frac{15}{8}L$$
I don't get the second point:
$$Lmg=m_1gx-m_3g\left( \sqrt{L^2+x^2}-L\right)\quad\rightarrow\quad x=\frac{3}{4}L$$
So also f(x0)=0, and i am left with:
$$E(x_0+h)=\frac{h^2}{2}f''(x_0)$$
That is correct.
I don't get what you want with the equation above. If the kinetic energy is mgL when the potential energy is zero, then the potential energy is mgL when the kinetic energy is zero.
I think you mean E as the potential energy, so $$E(x_0+h)=\frac{h^2}{2}E''(x_0)$$
Karol and ehild,
You guys have done an amazingly nice job of analyzing this problem. Congrats. I just have a little extra to add that I think you might find interesting.
If I combine the three force balance equations by eliminating the tensions in the two strings, I obtain the following equation:
$$m_1g-m_3g\frac{x}{\sqrt{L^2+x^2}}=(m_1+m_2)\frac{d^2x}{dt^2}+m_3\frac{x}{\sqrt{L^2+x^2}}\frac{d^2}{dt^2}\left(\sqrt{L^2+x^2}\right)$$
If I multiply this equation by dx/dt, I obtain:
$$m_1g\frac{dx}{dt}-m_3g\frac{x}{\sqrt{L^2+x^2}}\frac{dx}{dt}=(m_1+m_2)\frac{dx}{dt}\frac{d^2x}{dt^2}+m_3\left(\frac{x}{\sqrt{L^2+x^2}}\frac{dx}{dt}\right)\frac{d^2}{dt^2}\left(\sqrt{L^2+x^2}\right)$$
This equation can be reexpressed as:
$$m_1g\frac{dx}{dt}-m_3g\frac{d(\sqrt{L^2+x^2})}{dt}=\frac{(m_1+m_2)}{2}\frac{d}{dt}\left(\frac{dx}{dt}\right)^2+\frac{m_3}{2}\frac{d}{dt}\left(\frac{d(\sqrt{L^2+x^2})}{dt}\right)^2$$
Integrating this between 0 and t yields:
$$m_1gx-m_3g(\sqrt{L^2+x^2}-L)=\frac{(m_1+m_2)}{2}\left(\frac{dx}{dt}\right)^2+\frac{m_3}{2}\left(\frac{d(\sqrt{L^2+x^2})}{dt}\right)^2$$
The left hand side of this equation is minus the PE, and the right hand side is the KE.
Chet
Chestermiller said:
Karol and ehild,
$$m_1g-m_3g\frac{x}{\sqrt{L^2-x^2}}=(m_1+m_2)\frac{d^2x}{dt^2}+m_3\frac{x}{\sqrt{L^2-x^2}}\frac{d^2}{dt^2}\left(\sqrt{L^2+x^2}\right)$$
Thank you Chet!
But is not the first equation
The problem is not completely solved yet. The question "is the initial acceleration maximum" is not answered correctly, and I think, a simple answer is expected, without deriving the formula for d2x/dt2. And the question is sloppy as the acceleration of m1 and m2 differ from that of m3.
I do not think it is correct. Explain, please.
ehild said:
Thank you Chet!
Hi ehild,
Thanks for picking up on that typo. I've gone back and corrected it in all the equations to avoid confusing others.
Here's something else weird to think about. The acceleration of masses 1 and 2 is ##d^2x/dt^2##, but the acceleration of mass 3 is
$$\frac{x}{\sqrt{L^2+x^2}}\frac{d^2x}{dt^2}+\frac{L^2}{(L^2+x^2)^{3/2}}\left(\frac{dx}{dt}\right)^2$$
So when masses 1 and 2 are not accelerating, mass 3 is accelerating (unless dx/dt = 0, which it is not). So at the "equilibrium position" x = 0.75L , mass 3 is not in equilibrium.
Chet
Chet
Hi Chet,
I guess it was not the original text of the problem presented in the OP. I understood "equilibrium position" as the point (x) where the forces at all masses at rest are zero, that is all accelerations are zero. If m2 is put at that point, the system stays there.
If the system is released from the position where m2 is at the wall, it will accelerate at x=0.75L.
The mass m3 moves differently from m1 and m2. It would be interesting to see the motions in detail.
ehild said:
Hi Chet,
Ah...thanks.
Actually, when m2 arrives at x = 0.75L, its acceleration will momentarily be zero, but the acceleration of m3 will not be zero at 0.75L.
I'm thinking of solving the problem numerically just to see. It shouldn't be too hard to do on a spreadsheet.
Chet
$$\tan \alpha=\frac{8}{15}\quad\rightarrow\quad \cos\alpha=0.88$$
$$F=m_3g\cos\alpha-m_1g=1.4mg$$
$$1.4mg=m_2a\quad\rightarrow \quad a=0.12g$$
It's not logical since the distance to the equilibrium is shorter
Hi guys,
For your consideration, I've solved the equations numerically for the velocity and the location x as a function of time. First I reduced the differential equation to dimensionless form by introducing the following dimensionless parameters:
$$X=\frac{x}{L}$$
$$T=t\sqrt{\frac{g}{L}}$$
$$V=\frac{dX}{dT}$$
$$M_1=\frac{m_1}{(m_1+m_2+m_3)}$$
$$M_3=\frac{m_3}{(m_1+m_2+m_3)}$$
Then I substituted these into the differential equations to obtain:
$$M_1-M_3\frac{X}{\sqrt{1+X^2}}\left[1+\frac{1}{[1+X^2]^{3/2}}V^2\right]=\left[1-\frac{M_3}{1+X^2}\right]\frac{dV}{dT}$$
$$\frac{dX}{dT}=V$$
The numerical solution to the equations is shown in the figures below:
Note that the maximum distance is X = 15/8=1.875
$$X=\frac{x}{L}$$
$$V=\frac{dX}{dT}$$
$$M_3=\frac{m_1}{(m_1+m_2+m_3)}$$
$$\frac{dX}{dT}=V$$
View attachment 88525 View attachment 88526
It is amazing, Chet! It is clearly shown how asymmetric the motion is. Could you please plot the motion m1 and m3 together?
The tensions acting on m2 are not m1g and m3g, as these masses are accelerating.
Also, the turning point is at distance (15/8-3/4)L from the equilibrium point, farther than the equilibrium point from the initial position.
You can see from Chet's velocity plot, that it is less steep after the equilibrium point.
At the turning point the system is at halt but accelerating, so in order to find the acceleration of m2 there isn't any other way than to solve the differential motion equation? and in order to answer the question i use the fact that the distance to the equilibrium is bigger, so the acceleration must be smaller?
You do not need to solve any differential equation, only derive the expression for d2x/dt2. There will be a term proportional to (dx/dt)2, but it is zero at the turning point. Evaluate it at x=15/8 L.
I think, it is enough for the answer to say that the acceleration is determined by the weight of m1 initially, without any retarding force from T3. When the string is not vertical any more, there is a retarding force, so the acceleration must decrease till equilibrium is reached. After the equilibrium, the acceleration becomes negative, and you can argue with the asymmetry why its magnitude is less than the initial acceleration.
By the way, what was the original text of the problem?
Chestermiller said:
Here's something else weird to think about. The acceleration of masses 1 and 2 is d2x/dt2d^2x/dt^2, but the acceleration of mass 3 is:
I don't reach this derivative:
$$x_3=\left( \sqrt{L^2+x^2}-L^2 \right)$$
$$(x_3)'=\frac{x\dot x}{(L^2+x^2)^{\frac{3}{2}}}$$
$$(x_3)''=\frac{(L^2+x^2)(\dot x^2+x\ddot x)-x^2\dot x^2}{(L^2+x^2)^{\frac{3}{2}}}$$
$$(x_3)''=\frac{L^2(\dot x^2+x\ddot x)+x^3\ddot x}{(L^2+x^2)^{\frac{3}{2}}}$$
It is on the 1/2 power in the denominator.
$$(x_3)'=\frac{x\dot x}{(L^2+x^2)^{\frac{1}{2}}}$$
It is the same as Chet's. Collect the terms with ##\ddot x## pull out x ##\ddot x## and simplify.
In post#11:
I made only with the second method:
What is the first method, the one you talk about in: "Write the potential energy in terms of that x. It would be much simpler. Square the equation and solve."
And another question about this equation. on the left side, the 0, is it the difference in potential energy between the initial and the other turning point's states or can it also be viewed as the kinetic energy which is 0 at the turning points?
