- 23,753
- 5,953
No problem. The maximum on m3 is 9/8.ehild said:It is amazing, Chet! It is clearly shown how asymmetric the motion is. Could you please plot the motion m1 and m3 together?
Both.Karol said:In post#11:
I made only with the second method:
$$0=m_1gx-m_3g\left( \sqrt{L^2+x^2}-L \right)\quad\rightarrow \quad x=\frac{15}{8}L$$
What is the first method, the one you talk about in: "Write the potential energy in terms of that x. It would be much simpler. Square the equation and solve."
And another question about this equation. on the left side, the 0, is it the difference in potential energy between the initial and the other turning point's states or can it also be viewed as the kinetic energy which is 0 at the turning points?
Post #27:ehild said:The tensions acting on m2 are not m1g and m3g, as these masses are accelerating.
$$m_1g-m_3g\frac{x}{\sqrt{L^2+x^2}}=(m_1+m_2)\frac{d^2x}{dt^2}+m_3\frac{x}{\sqrt{L^2+x^2}}\frac{d^2}{dt^2}\left(\sqrt{L^2+x^2}\right)$$ehild said:You do not need to solve any differential equation, only derive the expression for d2x/dt2. There will be a term proportional to (dx/dt)2, but it is zero at the turning point. Evaluate it at x=15/8 L.
You made a calculation error. $$\sqrt{L^2+x^2}=\sqrt{4.52}$$Karol said:$$\left( m_1+m_2+m_3\frac{x^2}{L^2+x^2}\right)\ddot x=m_1g-m_3g\frac{x}{\sqrt{L^2+x^2}}$$
$$\left( 3+12+5\frac{3.52L^2}{L^2+3.52L^2}\right)\ddot x=3g-5g\frac{1.875L}{\sqrt{2.875L^2}}=-2.53g\quad\rightarrow\quad \ddot x=0.13g$$
$$\left( 3+12+5\frac{3.52L^2}{L^2+3.52L^2}\right)\ddot x=3g-5g\frac{1.875L}{\sqrt{4.52L^2}}=-1.41g\quad\rightarrow\quad \ddot x=0.005g$$ehild said:You made a calculation error.
Karol said:$$\left( 3+12+5\frac{3.52L^2}{L^2+3.52L^2}\right)\ddot x=3g-5g\frac{1.875L}{\sqrt{4.52L^2}}=-1.41g\quad\rightarrow\quad \ddot x=0.005g$$
It's much smaller than 0.12g that i found using simply the forces of m1 and m3 as if they'r at rest. is it wrong to consider them at rest? when i calculate the acceleration of a mass attached to a spring in SHM i also take the spring's force at the turning points
$$\left( 3+12+5\frac{3.52L^2}{L^2+3.52L^2}\right)\ddot x=3g-5g\frac{1.875L}{\sqrt{4.52L^2}}=-1.41g\quad\rightarrow\quad \ddot x=0.07g$$ehild said:The numerical result is wrong again, but it will be really less than 0.12g.
At the turning points, the velocities are zero, but the accelerations of m1 and m3 are not zero. This is true even in simple harmonic motion. So the force balances on m1 and m3 at the turning points have to include their (non-zero) accelerations.Karol said:$$\left( 3+12+5\frac{3.52L^2}{L^2+3.52L^2}\right)\ddot x=3g-5g\frac{1.875L}{\sqrt{4.52L^2}}=-1.41g\quad\rightarrow\quad \ddot x=0.07g$$
I know the accelerations of m1 and m3 are different but at the turning points they stop, so why can't i consider the static forces like in post #22:
$$\tan \alpha=\frac{8}{15}\quad\rightarrow\quad \cos\alpha=0.88$$
$$F=m_3g\cos\alpha-m_1g=1.4mg$$
$$1.4mg=m_2a\quad\rightarrow \quad a=0.12g$$
Stop does not mean zero acceleration.Karol said:I know the accelerations of m1 and m3 are different but at the turning points they stop, so why can't i consider the static
I started out by substituting the equation for the acceleration of mass 3Karol said:In post #23 Chet introduced the dimensionless time ##T=t\sqrt{\frac{g}{L}}##, why is it built this way?
Are the dimensionless variables inserted into:
Or into:
$$m_1gx-m_3g(\sqrt{L^2+x^2}-L)=\frac{(m_1+m_2)}{2}\left(\frac{dx}{dt}\right)^2+\frac{m_3}{2}\left(\frac{d(\sqrt{L^2+x^2})}{dt}\right)^2$$
I don't understand at all how you reached:
$$M_1-M_3\frac{X}{\sqrt{1+X^2}}\left[1+\frac{1}{[1+X^2]^{3/2}}V^2\right]=\left[1-\frac{M_3}{1+X^2}\right]\frac{dV}{dT}$$
I understand the member ##\frac{X}{\sqrt{1+X^2}}## (i substituted x=XL). do you substitute V for ##\dot x## and ##\frac{dV}{dT}## for ##\ddot x##? why is it allowed?
Do you substitute m1 with M1 or do i "open"
$$M_1=\frac{m_1}{(m_1+m_2+m_3)}$$
And
$$M_3=\frac{m_1}{(m_1+m_2+m_3)}$$
Where can i find material about this method?
I solved the pair of differential equations of the form dV/dT= f(X,V) and dX/dT=V on an Excel spreadsheet using a simple numerical integration scheme (a slightly modified version of the so-called forward Euler scheme) that I set up. I then copied the table of results into Kaleidagraph, a nice graphics package, and plotted the results. It all took me about half an hour.Karol said:Yes, Chet, i am OK so far and i thank you very much.
I now understand you solved this differential equation ##X=f_1(T)## numerically, plotted one graph, and plotted ##\dot X=f_2(T)##. with which program did you do it?]
In order to get the equations into a convenient mathematical form to carry out the numerical integration scheme, my motivation was to express the acceleration d2x/dt2 explicitly as a function of dx/dt and x. That's how I ended up with the dimensional version of the final equation for d2x/dt2. I then wanted to reduce the equations to dimensionless form in order to minimize the number of parameters involved in the analysis and to reduce the equations to their bare fundamental essence. The way I was taught to do this as a student was to express dimensional parameters like x and t in the general form x/x0=X and t/t0=T. You then make these substitutions into the differential equations (and initial- and boundary conditions, if appropriate), and choose x0 and t0 in such a way that they cancel and eliminate as much as possible. In this case, the compelling choices turned out to be x0=L and ##t_0=\sqrt{L/g}##. In the final equations, the only adjustable parameters are M1 and M3, rather than m1, m2, m3, L, and g. That's an example of why expressing everything in terms of dimensionless parameters is such a powerful technique.Did you choose ##T=t\sqrt{\frac{g}{L}}## this way in order for the members to cancel and reach the form of the above, last equation? how did you do it all in advance, all these substitutions and actions?
