What absorbs impact better, hard plastic or silicon?
The discussion revolves around the effectiveness of hard plastic versus silicone in absorbing impact for protecting a GoPro camera mounted on an FPV drone. Participants explore material properties, potential alternatives, and the importance of design in impact absorption.
  • Some participants assert that silicone absorbs shock better than hard plastic.
  • Others challenge this claim, noting that silicon, as used in semiconductors, is brittle and questioning the availability of suitable silicone for encasing a GoPro.
  • One participant suggests considering alternatives like Styrofoam or foam rubber for better energy absorption.
  • There is mention of the common use of various plastics, such as polycarbonate, in mobile phone cases.
  • Participants highlight that the effectiveness of impact absorption also depends on factors like the design of the case and the thickness of the silicone.
  • Clarifications are made regarding the difference between silicone and silicon, with humor noted in the distinction.
Participants express differing views on the impact absorption properties of silicone versus hard plastic, with no consensus reached on which material is superior. The discussion remains unresolved regarding the best material choice for protecting the GoPro.
Participants note that the effectiveness of the materials may depend on specific design considerations, such as how the camera is mounted and the mechanical weak points of the camera.
captaincrouton
Hello,
Not sure really where to ask this but I couldn't find a good answer so why not a physics forum, because well this involves physics. I just got a gopro for my fpv drone and I am wondering what type of case to get for it, either a plastic or silicone one. If I am going 30+ mph and smack into a tree what would absorb most of that energy and protect the gopro?
Thanks
silicon- absorbs shock better
if you use plastic it will most likely crack depending on how hard it is
wonder where you got that info from ?
the silicon I see in semiconductors is very brittle
and I have no idea where you would get sufficient quantities from to encase a gopro ?
maybe you would be much better looking at Styrofoam or foam rubber
Dave
Dave
when he said silicon I was assuming a sort of malleable silicon case that is commonly seen in phone cases, not conductor silicon - however I see your point and foam rubber sounds feasible
most mobile phone cases are plastics of one type or another, polycarbonate etc
There are both plastics and silicone based materials that could be used as a shock absorber.
With plastics you have more choice and they are cheaper.
It's not just about the material, but the specific design:
- How the camera is mounted inside the hard box
- How thick the silicon is
- The mechanical weak points of the camera
silicone :wink:
  • · Replies 31 ·
  • · Replies 29 ·
9K
