What Actually Happens vs What You See in SR
  • Context: Undergrad
  • Thread starter Thread starter Afterthought
    Light Special relativity
The discussion revolves around the relationship between what is observed in special relativity (SR) and the underlying physical phenomena. Participants explore whether calculations in SR inherently account for the effects of light travel time and how this impacts the interpretation of relativistic effects. The scope includes theoretical considerations, conceptual clarifications, and references to relevant literature.
  • Some participants suggest that typical descriptions in SR do not explicitly account for light travel time, which may lead to misunderstandings about what is "seen" versus what occurs physically.
  • Others argue that the physical description of events in SR is often sufficient without considering what an observer would see, as the focus is on measurements and relationships in spacetime.
  • A participant notes that the term "observer" in SR usually refers to an inertial frame of reference rather than a physical entity, implying that light travel is not a necessary consideration in many analyses.
  • One participant references classical physics to illustrate that visual changes in rapidly moving objects do not reflect actual changes in the objects themselves, paralleling this with relativistic effects.
  • Another participant provides a mathematical outline of how to incorporate light travel into calculations, suggesting that it can be done but is often not rigorously followed in typical discussions.
Participants express differing views on whether light travel time is inherently included in SR calculations. Some believe it is not typically accounted for, while others assert that it is not relevant to the physical description unless specifically addressing observational scenarios. The discussion remains unresolved regarding the necessity and implications of including light travel in SR analyses.
There are limitations in the discussion regarding assumptions about what constitutes an "observer" and how visual perception relates to physical events. The mathematical steps provided are not rigorously established and depend on specific conditions that may not be universally applicable.
This discussion may be of interest to those studying special relativity, particularly in understanding the nuances of observational effects versus theoretical descriptions, as well as those looking for mathematical approaches to incorporate light travel considerations in relativistic contexts.
Afterthought
My impression always was that when you describe a problem in special relativity, you are already implicitly taking into account the light that would need to travel for some person to theoretically "see" a special relativistic phenomenon. I was confronted recently in another thread that this impression was wrong.
My question is, is this correct? If so, then after you do your problem using the Lorentz Transformations, or geometrically using the space-time interval, to determine what a person actually sees, you need to do additional computations! Yet, I have never seen this step done personally (granted I learned SR on my own). Is there a reason for this? Is it perhaps that usually this additional computation doesn't change the end result much - or at all - and so we don't usually do it? Are there any guidelines then when to and not to take traveling light into account?
Or is it the case rather that the initial conditions we give already take light into effect? In either case, are there some equations to help transform between what you "see" and what actually happens? Or is it something that you always have to do geometrically? Unless, since it's possible I misunderstood, that what you see and what actually happens are one and the same.
Thanks.
Yes.
What a physical observer actually sees is not that relevant to the physical description unless this is actually your experiment.
I remember some animations on the aberration and Doppler shift of light on Wikipedia that do show this, but I am on my mobile and cannot check at the moment.
Thanks.
In my view SR is about the geometry of spacetime, events and relationships between them, and how events map to frames of reference / coordinate systems. Descriptions of SR scenarios would typically include wording like "measure", "observe" (to also mean "measure" rather that "see"), and unfortunately the sloppy "see" but also generally synonymous to the previous two. "See" rarely means what one actually sees, since that's largely irrelevant.
Also, "observer" mostly means an inertial fame of reference (IFR) rather than a physical entity (object, person) at a particular location in space. So the observer is everywhere and everywhen events happen, no need to account for light travel.
SR becomes quite straightforward once you train your mind to think in terms of events and frames of reference. The first step in analyzing a scenario should be to identify all the relevant events and IFRs and then just use those going forward.
http://www.spacetimetravel.org/
Check out (at least) the first two paragraphs in The Visual Appearance of Rapidly Moving Objects by V.F. Weisskopf: http://www.phy.pmf.unizg.hr/~npoljak/files/clanci/weisskopf.pdf
Even in classical physics there are apparent, i.e. visual, changes in the shape of an object that is moving very fast. The object itself is not changing, it just appears that way to an observer or on a photograph. Likewise in relativity, what is calculated is what would be measured in a reference frame with distributed clocks and measuring rods, not what a person would see.
Not that I know of. Here's an outline of the process in 1+1D, it's not at all rigorous but it shows the extremely simple algebraic steps required:
The Lorentz Transform in 2 dimensions is:
t' = \gamma (t - vx)
x' = \gamma (x - vt)
If we apply the light travel "boundary conditions" $$t = \pm x$$ then we can easily calculate what we can see in 1+1 dimensions. Let's do time first; there are two cases, corresponding to plus and minus (left or right) respectively:
t' = \gamma (t - vt) = \gamma (1 - v) t = \frac { (1 - v) } { \sqrt{1 - v^2} } t = \frac { (1 - v) } { \sqrt{(1 - v) (1 + v)} } t = \sqrt {\frac { 1 - v } { {1 + v} } }t
t' = \gamma (t + vt) = \gamma (1 + v) t = \frac { (1 + v) } { \sqrt{1 - v^2} } t = \frac { (1 + v) } { \sqrt{(1 - v) (1 + v)} } t = \sqrt {\frac { 1 + v } { {1 - v} } }t
Similarly for space:
x' = \sqrt {\frac { 1 - v } { {1 + v} } }x
x' = \sqrt {\frac { 1 + v } { {1 - v} } }x
and thus we end up with the Doppler relations.
Thank you for the links, checking them out right now.
The derivation of the Doppler relations also seem helpful, I will try seeing (pun intended) if I can apply them to a simple problem.
  • · Replies 54 ·
  • · Replies 27 ·
  • · Replies 26 ·
  • · Replies 54 ·
  • · Replies 19 ·
  • · Replies 73 ·
  • · Replies 65 ·
14K
