What angular speed is the stick spinning after the collision?
The discussion revolves around calculating the angular speed of a stick after being struck by a bullet. A uniform stick, pivoted at its center, is hit by a bullet, and the conservation of angular momentum is emphasized as the key principle to solve the problem. Participants clarify that kinetic energy is not conserved in this inelastic collision, and they derive the relationship between linear and angular momentum. The moment of inertia for the bullet is treated as a point mass at the collision point, allowing for the calculation of the stick's angular speed post-collision. Ultimately, the calculated angular speed of the stick is 4.8 rad/sec.
saturn67
A uniform stick 1.0 m long with a total mass of 220 g is pivoted at its center. A 3.2 g bullet is shot through the stick midway between the pivot and one end The bullet approaches at 250 m/s and leaves at 140 m/s
With what angular speed is the stick spinning after the collision?
I*wi=I*wf
I of stick = (1/12)ML^2K= (1/2)(Mb*Vf^2+(1/2)Iw^2
(1/2)*Mb*Vi^2 = (1/2)(Mb*Vf^2+(1/2)Iw^2
i use the above equaltion but it wrong
anyone got any idea how to solve this XD
please help me ^_^
Hi saturn67,
Since this is not an elastic collision, kinetic energy is not conserved and so
is not true.
What is conserved in this collision?
angular momentum conserved?
I*wi = I*wf
but bullet don't have angular momentum?
so 0=I*wf
so it don't make sense >.<
Yes, that's right. So your first equation (written out for two separate objects)
I_{1} \omega_{1,i} +I_{2}\omega_{2,i} =I_{1} \omega_{1,f} +I_{2}\omega_{2,f}
should lead to the answer. What do you get?
how to relate I1*w1i to bullet??
i know I2w2i= 0 since stick is at rest
We can treat the bullet as a point particle. What is the moment of inertia of a point particle at the point where it hits the stick? We know its linear speed; how is that related to its angular speed?
humm
soo L= R cross P
p= mv
so L=m1*v1*r
is right?
saturn67 said:
humm
soo L= R cross P
p= mv
so L=m1*v1*r
is right?
Yes, that's a good way to do it. So you know:
<br /> I_1 \omega_{1,i} = m_1 v_1 r_1<br />
and you can do the same thing for the angular momentum of the bullet after the collision. Once you find I_2\omega_{2,f}, you can then solve for \omega_{2,i}.
(If you had done them separately you would find I=m r^2 and \omega=v/r, which would have given the same answer of mvr.)
ok thank a lot alphysicist that is a big help XD
yep i got it
w= 4.8 rad/sec
  • · Replies 20 ·
