Comp Sci What are the differences between a virtual node and a physical one
  • Thread starter Thread starter Ander99
    Physical Virtual
The discussion focuses on the differences between physical nodes and virtual nodes, particularly in the context of circuit analysis. A physical node refers to a tangible connection point in a circuit, while a virtual node is an abstract concept used in analysis, such as a virtual ground in op-amps. Participants express confusion about the term "virtual node" and its applications, with one mentioning its use in nodal analysis where it simplifies calculations. The conversation highlights the need for clarity on these concepts, especially for those unfamiliar with circuit theory. Understanding these differences is crucial for effective circuit design and analysis.
Ander99
Find the differences between a virtual node and a physical one.
none
Hi everyone! Can someone explain which are the differences between a physical node and a virtual one and which one is potentially better . I've been looking for information but I haven't found anything.
Thank you a lot.
Ander99 said:
Homework Statement:: Find the differences between a virtual node and a physical one.
Relevant Equations:: none
Thank you a lot.
My Google-foo is not helping me on this. Where did you see the term "virtual node"?
I, too, am at a bit of a loss here. Perhaps something like a virtual ground at an op-amp input? Two (essentially) separated nodes that are constrained to have the same potential via some mechanism that isn't a simple wire connection?
I do recall when studying computer methods for circuit analysis that one technique for implementing nodal analysis involved creating a virtual ground node just "floating in space" rather than choosing an existing node in the circuit. You end up with one extra node equation to write, but since the computer was doing it and presumably the circuit in question had many, many nodes to begin with anyways, it was not a significant cost in complexity.
Likes berkeman
