What are the Eigenvalues and Eigenvectors of Similar Matrices
The discussion revolves around the properties of similar matrices, specifically focusing on their eigenvalues and eigenvectors. The original poster seeks to understand why similar matrices A and B share the same eigenvalues.
  • Participants explore the definition of similar matrices and their implications on eigenvalues and eigenvectors. Some question whether eigenvalues uniquely characterize a matrix, while others suggest examining characteristic polynomials. There are attempts to derive relationships between the matrices using equations involving eigenvalues and characteristic polynomials.
The discussion is active, with various participants offering different perspectives on how to approach the problem. Some have provided hints and alternative methods for proving the relationship between the eigenvalues of similar matrices, while others express confusion about the terminology used in the problem.
There is a noted change in terminology from "equation" to "polynomial," indicating a focus on the characteristic polynomial. Participants also reflect on the nature of eigenvectors in relation to similar matrices, questioning whether they can be the same or different.
Jennifer1990
Let A and B be similar matrices
a)Prove that A and B have the same eigenvalues
None
Firstly, i don't see how this can even be possible unless the matrices are exactly the same :S
So you think that eigenvalues uniquely characterize a matrix? What about
and
for example?
You've put 'none' for relevant equations. That isn't true - there's a definition of 'similar' and many for 'eigenvalue'. Try it. HINT: polynomials.
EDIT: Changed "equation" to "polynomial"
You have to show that A and B=P^-1AP (for some invertible matrix P) have the same characteristic polynomial.
Oh, I think that way is much too complicated!
Do it directly from the equation:
If [itex]Av= \lambda v[/itex] then, for any invertible P, [itex]P^{-1}Av= \lambda P^{-1}v[/itex]. Now define [itex]u= P^{-1}v[/itex].
Your way is too easy. :smile:
or let [tex]Av = \lambda v[/tex]
then [tex]AP^{-1}Pv = \lambda v[/tex] and go from there
what do u mean by the same characteristic equation?
EDIT: changed "equation" to "polynomial"
The the characteristic polynomial of matrix A is [tex]det(A- \lambda I).[/tex]
The characterisitc polynomial of matrix B is [tex]det(B - \lambda I) = det(PAP^{-1} - \lambda I)[/tex]
so show that [tex]det(A- \lambda I) = det(PAP^{-1} - \lambda I)[/tex]
But there are easier ways as HallsofIvy noted.
Start with [tex]Av = \lambda v[/tex] where v is a nonzero vector
then [tex]AP^{-1}Pv = \lambda v[/tex] since [tex]P^{-1}P = I[/tex]
Do you know what to do next?
A and B are similar if and only if they both represent the same linear map, with respect to two possibly different bases. Eigenvalues are defined independently of what basis, if any, you choose. QED.
Random Variable said:
The the characteristic equation of matrix A is [tex]det(A- \lambda I).[/tex]
Make that "The characteristic equation of matrix A is [tex]det(A- \lambda I) = 0.[/tex]"
For it to be an equation, it at least has to have an equals sign.
Sorry. What I should have said is that they have the same characteristic POLYNOMIAL. :redface:
Av = lambda v
(AP^-1 P)v = lambda v
Bv = lambda v
i think?
oh wait...B = P^-1 AP ...so what i said is wrong...
how can i manipulate A P^-1 P to look like P^-1 AP?
ohhh i see...
since they can have the same eigenvalues, does this mean that the matrices can also have the same eigenvectors?
Jennifer1990 said:
ohhh i see...
They can, but it's not likely.
I just tried several similar matrices but they all share the same eigenvector O.o
Can i get an example where two similar matrices have different eigenvectors?
I'm surprised you were able to find similar matrices that had the same eigenvectors!
[tex]A= \begin{bmatrix}2 & 0 \\ 0 & 3\end{bmatrix}[/tex]
has, obviously, 2 and 3 as eigenvalues with corresponding eigenvectors <1 0> and <0 1>.
[tex]B= \begin{bmatrix}1 & -1 \\ 2 & 4\end{bmatrix}[/tex]
has the same eigenvalues with corresponding eigenvectors <1, -1> and <1, -2>.
All I did was start with the obvious diagonal matrix, A, choose a simple invertible P:
[tex]P= \begin{bmatrix}2 & 1 \\ 1 & 1\end{bmatrix}[/tex]
and calculate [itex]B= P^{-1}AP[/itex].
  • · Replies 19 ·
  • · Replies 19 ·
