What are the equations for solving combined circuit problems?
The discussion revolves around understanding combined circuit problems, specifically focusing on series and parallel circuits. Participants are exploring the relevant equations and concepts related to current and resistance in these types of circuits.
  • Exploratory, Conceptual clarification, Problem interpretation, Assumption checking
  • Participants are attempting to identify which resistors are in series or parallel and are questioning how to determine the flow of current through the circuit. There are discussions about the relationships between different resistors and their configurations.
The conversation is ongoing with various participants providing insights and asking clarifying questions. Some guidance has been offered regarding analyzing current flow, but there is still uncertainty about the definitions of series and parallel circuits. Multiple interpretations of the circuit layout are being explored.
There is a noted lack of clarity in the original poster's understanding of the problem, and some participants express concern about the level of difficulty for a 10th-grade student. The original poster has not clearly stated the specific problem they are trying to solve.
j doe
IR=V
series circuit
Vt = V1 + V2 + V3...
It = I1 = I2 = I3...
Rt = R1 + R2 + R3...
parallel circuit
Vt = V1 = V2 = V3...
It = I1 + I2 + I3...
Rt = 1/R1 + 1/R2 + 1/R3...
i honestly have no idea where to start. may someone pls help me?
Can you identify any resistors which are in series and can be combined?
is 2 and 4 in a parallel circuit as well as 3 and 5?
Here is something which helped me a lot when I was solving circuits
"Analyse how he current flows.If you find the same current going into different resistors they are in series,If different current flow flow through them they are in parallel"
i'm not sure how to tell that apart.
When the current reaches the bottom end of resistor 5, where will it go?
back to resistor 1?
j doe said:
back to resistor 1?
No. I mean the bottom end of 5, in the lower right corner. The current flows down through 5, and then where?
oh to resistor 4?
j doe said:
oh to resistor 4?
Right. And then when it leaves 4, where does it go?
resistor 3 and when it leaves 3, it goes to 2? and when it leaves 2, it goes to 1?
Not quite. When it leaves 3, there are two places it can go. But, looking at sidt36's post #4, what can you say about 3, 4, and 5?
3, 4, and 5 are parallel to each other. does that mean that 1 and 2 are series?
No! Read sidt36's post again.
No.
phyzguy said:
No!
No.
is it the opposite?
I'm not going to do the problem for you.
yes, i understand that but i don't get what makes a circuit a series or parallel.
Try making a diagram like this and check where the the current is going
And I hope you don't mind if I ask which grade you are in because this should be pretty trivial for 10th grade student
i am in 10th grade and i recently just learned this
You haven't stated what you are trying to solve for. What do you need to find? What is the actual problem statement?
Well keep practicing
I recommend a video
