What Are the Inclinations of Planetary Orbits Relative to the Sun's Equator?
The discussion centers on determining the inclinations of planetary orbits relative to the Sun's equator, which is known to be 7.25 degrees inclined to the ecliptic. Participants suggest using the JPL Horizons system to find planetary inclinations with respect to the ecliptic and then adjusting for the Sun's equatorial inclination. However, the complexity arises from the need to specify a complete reference system, as inclinations oscillate over time and depend on the longitude of the ascending node. A precise calculation requires careful consideration of these factors, and participants emphasize the importance of using accurate orbital elements. Ultimately, the original poster found the needed information through the discussion.
Leo Klem
Does anyone know the inclination of each planetary orbit (in degrees) with respect to the plane of the Sun's equator-plane?All planetary inclinations are known with respest to the ecliptic, and the ecliptic's inclination is known with rescpect to the Sun's equator (7.25 degrees). Such data, however, seem to me not sufficient for a precise calculation of the answer I need.
Astronomy news on Phys.org
Hi Leo - The authority on these things is the JPL Horizons system.
I'm not sure if you can use the sun's equator, but you'll certainly be able to find the inclination of each planetary orbit with respect to the ecliptic, then do the arithmetic by adding/subtracting the 7.25 deg. (At least it seems that simple at first look . . . )
Note that inclination, like other orbital elements, actually osculates, meaning it changes ever so slightly over time. So look in the osculating elements of your results after you submit your object data. The inclination is given by the quantity "IN", which is in degrees by default.
hth
What you suggest doesn't work, as I've already pointed out, when stating that those data are not sufficient; because there is no criterion to chose whether each particular orbit inclination has to be added or subtracted with/from 7.25 degrees.
Use the inclination and the longitude of ascending node.
Yup, that's the answer. You have to specify a complete reference system, and if you throw out the ecliptic as your reference frame, you also throw out Earth's ascending node as the reference zero-degree direction. You can either retain it, or look at each orbit independently in terms of its ascending node, or something more clever.
Without knowing more about what you're trying to do, I'm thinking that's the best we're going to be able to do for you.
I referred you to JPL's horizons because you said you were seeking precision.
You're welcome.
Thanks to Spacester and DH. I got the answer.
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
This thread is dedicated to the beauty and awesomeness of our Universe. If you feel like it, please share video clips and photos (or nice animations) of space and objects in space in this thread. Your posts, clips and photos may by all means include scientific information; that does not make it less beautiful to me (n.b. the posts must of course comply with the PF guidelines, i.e. regarding science, only mainstream science is allowed, fringe/pseudoscience is not allowed). n.b. I start this...
How does light maintain enough energy in the visible part of the spectrum for the naked eye to see in the night sky. Also, how did it start of in the visible frequency part of the spectrum. Was it, for example, photons being ejected at that frequency after high energy particle interaction. Or does the light become visible (spectrum) after hitting our atmosphere or space dust or something? EDIT: Actually I just thought. Maybe the EM starts off as very high energy (outside the visible...
