What are the Practical Uses of Oldham Couplers in Various Machines?
  • Thread starter Thread starter farhad_mech
    Coupling
The discussion revolves around the practical uses of Oldham couplers in various machines, exploring their applications and relevance in modern engineering contexts. Participants inquire about specific machines that utilize Oldham couplers and debate their practicality in contemporary settings.
  • One participant seeks information on practical uses and examples of machines that employ Oldham couplers.
  • Another participant notes that Oldham couplers are used for coupling parallel shafts at some radial distance.
  • Concerns are raised about the current practicality of Oldham couplers, with one participant suggesting they are not commonly used today due to frictional losses and the availability of better alternatives.
  • A participant mentions that Oldham couplers are still used in CNC machines and requests further examples.
  • Another participant claims that Oldham couplers are widely used in pump applications, particularly for connecting electric motors to pumps.
  • There is a discussion about the advantages of using couplers to allow for misalignment between shafts to prevent excessive loads on bearings.
Participants express differing views on the current relevance of Oldham couplers. While some argue they are outdated and less practical, others assert they are still extensively used in specific applications like pumps.
Participants mention limitations such as frictional losses and suitability for small radial distances, but do not reach a consensus on the overall practicality of Oldham couplers in modern machinery.
Individuals interested in mechanical engineering, machine design, and applications of couplings in various engineering contexts may find this discussion relevant.
farhad_mech
hello
our prof talked about oldham coupler and showed us some animations of how it works,
but didn't mention about where and in which machines it is is used,
anybody knows some practical uses of oldham coupler and some examples
of machines this coupler is used in?
thanks
its an oldie. it works in labs now.lolz...
Practical use? What do you observe when you see it? Its a coupling for parallel shafts at some radial distance
thanks for answer.i know "Its a coupling for parallel shafts at some radial distance",i want to know name of some machines that use it,searching in google i found that it is used in cnc machines,is there any specific other machines that use this couplig?
you said it works in labs now,you mean toadays oldham coupler is not used anymore?
:frown:can you show us a link?
I won't say anymore, but I haven't seen it so far other than my kinematics lab as an inversion of a 4 bar chain.
It isn't practical anymore for today's world. First, its a lower pair, has sooo much frictional loss, second, it is suitable for very small radial distances, there are better(efficient as well as cheap) options.
These couplers are used all over, especially in pump applications.
Look at companys like Lovejoy.
I'd have to disagree with that. They're used extensively for coupling electric motors to pumps, especially centrifugal pumps. I use a type of this coupling for connecting the drive shafts of two pumps together, so there are a lot of uses.
Generally, they're used when there are two shafts that need to be connected, and the shafts are both fully supported by bearings. If the shafts were directly coupled (ie: locked together as a single shaft) then any misalignment would create huge loads on the bearings which would wear out prematurely. So the coupling allows for some misalignment between fixed shafts so there won't be excessive loads created on the bearings.
hmm, nice solution. :smile:
thank you so much Q_Goest and FredGarvin,i think i have my answer now.
yeah me too, thanks q_goest & fred
  • · Replies 43 ·
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 20 ·
