What are the remaining steps to complete this problem?
  • Thread starter Thread starter HelloMotto
    Tangent
The discussion focuses on solving a calculus problem involving the function y = x² + 3x - 4. Key tasks include finding the equations of tangents and normals at specific points, determining local extrema, and calculating areas enclosed by tangents and axes. The user successfully completed parts a to c but encountered difficulties with parts d and e, particularly in understanding the conditions for tangents from the point (2, -4) and the area calculation related to the tangent at x = -2. The solution emphasizes the need to find a point on the curve that satisfies specific slope conditions for part d and clarifies the area calculation for part e.
  • Understanding of calculus concepts such as derivatives and tangent lines.
  • Familiarity with quadratic functions and their properties.
  • Knowledge of slope calculations and area of triangles.
  • Ability to graph functions and interpret graphical information.
  • Study the process of finding tangent lines to curves, particularly for quadratic functions.
  • Learn how to calculate the area enclosed by lines and axes using integration or geometric methods.
  • Explore the concept of local minima and maxima in calculus, including the first and second derivative tests.
  • Investigate the relationship between slopes of secant and tangent lines in the context of calculus.
Students studying calculus, particularly those focusing on derivatives, tangent lines, and area calculations related to curves. This discussion is beneficial for anyone tackling similar homework problems in mathematics.
HelloMotto
Given the function
y = x^{2} + 3x - 4 find,
a) the equation of tangent + normal at x = -2.
b)the equation of the tangent that has slope of -2.
c)local min and max.
d)the equations of the tangent from the point (2 , -4) to the curve.
e) area enclosed by the tangent at x = -2 and the axis.
ok so i did parts a to c. I am kind of stuck at part d and e. I don't understand what the questions mean.
d) Notice that (2, -4) is not on the curve. We want the equations of all lines passing through (2, -4) that are tangent to the curve. There could be 0, 1, or 2 of these lines because y is a quadratic. Let (x, y) be a point on one such line that's also on the curve. Then you know what y is in terms of x, and you can find the slope of the line in 2 ways: by differentiation, and by rise over run from (x, y) to (2, -4).
e) You found the equation of the tangent at x = -2 in part (a). Graph it and calculate the area of the triangle enclosed by this line, the x-axis, and the y-axis.
Part d is a bit tricky, I think. You want to find a point A on the parabola with coordinates (p, p^2 + 3p - 4) that satisifies these conditions:
  1. The slope of the segment from A to (2, -4) is equal to the slope of the tangent at A (p, p^2 + 3p -4).
  2. There is only one value of p that works.
I haven't worked through this, but this is the approach I would take for starters. The reason for the second condition is that the tangent has to touch the graph of the parabola at exactly one point; it can't intersect the graph at a point and then continue to intersect the other side of the parabola graph.
Part e is not well-defined. Did the original problem say "area enclosed by the tangent at x = -2 and the axes"? One axis, two axes. If so, the area involved is a triangle, so if you can find the intercepts of the tangent on the two axes, it's pretty easy to find the area of that triangle.
I don't understand why the tangent slope is equal to the regular slope.
I'm not sure what you're asking. What do you mean by "regular slope"?
sorry. I was referring to the slope from point A to point (2 , 4)
Your problem asks for "the equations of the tangent from the point (2 , -4) to the curve."
I interpret this to mean the line that is tangent to the given curve at A(p, p^2 + 3p + 4)and that passes through (2, -4). Can you find the slope of this line segment? Can you find the slope of the tangent line to the curve at point A? The two expressions you get will involve p and have to be equal.
