What are the tensions in the strings for a rotating object?
  • Thread starter Thread starter tnhoots
    Tension
8 replies · 2K views
tnhoots
More tension prolbmes!
A 4.95 kg object is attached to a vertical rod by two strings. The object rotates in a horizontal circle at constant speed 7.25 m/s. the length of both strings is 2.00m and the length of the vertical rod is 3.00m.
(a) Find the tension in the upper string.
N
(b) Find the tension in the lower string.
N
equation for radius: r^2=c^2 - b^2
radius equals 1.32m
If i could have a picture of the set or something..
I could not copy and past the pic...it wouldn't let me paste it on here. It's pretty much a vertical rod with a string coming from the top and the bottom corners to form a triangle. That's the best way I know how to depict it. Sorry
You can upload the image by going to http://imageshack.us, and clicking "Browse". Then just locate the image on your hard drive and press upload. Use the link you are given to show the picture.
the cent. acceleration is v^2/r. Which is 19.6^2/10=38.416
The problem is pretty straight forward. The acceleration only has one component which is the radial one, so the speed is constant. Use trigonometry to find the radius and to set the component of the tension in the direction of the radial acceleration.
