What are the Unknown Resistances in this Circuit with Given Current and Voltage?
  • Thread starter Thread starter physicsxnoob
    Circuit
The discussion revolves around a circuit problem where the resistance values are unknown, but the current (10A) and voltage (220V) are provided. Participants are trying to understand how to approach the problem given the lack of specific resistance values and the complexity of the circuit setup.
  • Participants discuss the challenge of solving for multiple unknown resistances with limited information. Some suggest making assumptions about the values of resistances to simplify the problem, while others question the feasibility of finding a solution without more data.
The discussion is ongoing, with various interpretations of the problem being explored. Some participants have suggested pragmatic approaches, such as assuming equal resistance values or considering some resistances as zero, while others express skepticism about the possibility of finding a solution given the constraints.
There is a mention of a specific condition where the sum of certain resistances should equal 1/19, but the lack of explicit definitions for the resistances complicates the analysis. The original poster's request for guidance indicates a need for clarification on how to proceed with the problem.
physicsxnoob
I have this circuit problem, The Resistance is not given yet the Current is 10A and Voltage is 220V
my professor told me that A is the only series, A's value could be = to 3. D to Y is 1 over ? and B to C is also 1 over ? it's really hard but here's the picture link of the circuit.
He even told me that if you add D to Y and B to C it should be = to 1 over 19
can someone give me the value of Ra to Rz ? with a little bit explanation on how you come up
to the answers.
https://fbcdn-sphotos-e-a.akamaihd.n...72073306_n.jpg
thank you~
The image is not accessible. The link to it is messed up.
sorry~
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-ash4/s480x480/488389_518468254845450_1272073306_n.jpg
is it accessible already?
So, you want to solve for 26 unknowns given only two known values (voltage and current)? That ain't going to happen!
I think you'll have to make some "creative" assumptions (i.e., cheat :smile: ).
My other classmates gave up too. Some of them says that it's impossible / hard to answer this circuit if the R = Resistance is not given. Since Resistance could be any value in this situatuion.
I'm hopeless. :)
Since no other conditions a given, you can approach this pragmatically: do whatever it takes to solve it with the least effort. So you could just say: let them be all equal. What is the value then?
Still too much work in my opinion. I've got a devious mind; There's another possible approach that would make for a trivial solution :wink:
Well, you could make some R's zero. But that could be considered, like you said, cheating. But that is a valid approach if R's can really be ANYTHING.
I'd say use whatever latitude the problem statement does not specifically forbid or constrain. It's the problem author's responsibility to clearly define the parameters and limits of the problem, and if he leaves the door wide open to trivial solutions based on convenient assumptions for unspecified values, then take advantage of it.
If there is nothing in the problem statement that forbids making some or all of the values zero, go for it and save the brain sweat.
I guess its a really hard problem isn't? Well then, thank you guys so much for dropping by here. At least your presence made me believe that even me, I can't answer it too.
And thanks for your time again.. :)
I don't think it's hard. Just missing some information.
When the prof said A "could be 3" perhaps he was just suggesting you just pick non zero values that give a workable solution. eg to show you know how to solve series and parallel circuits.
He may even be hoping that you manage to do it with standard/preferred values :-)
What if you assume that Ra - Rz all have the same value?
Obviously, your teacher wants the full set of solutions to
a+(b+c)(((q+r+s+tu/(t+u)+z)(m+n+op/(o+p)+vw/(v+w))/((q+r+s+tu/(t+u)+z)+(m+n+op/(o+p)+vw/(v+w)))+x+y)((e+f)(h+i)(k+l)/(e+f+h+i+k+l)+j)/(((q+r+s+tu/(t+u)+z)(m+n+op/(o+p)+vw/(v+w))/((q+r+s+tu/(t+u)+z)+(m+n+op/(o+p)+vw/(v+w)))+x+y)+((e+f)(h+i)(k+l)/(e+f+h+i+k+l)+j))+d+g)/(b+c+(((q+r+s+tu/(t+u)+z)(m+n+op/(o+p)+vw/(v+w))/((q+r+s+tu/(t+u)+z)+(m+n+op/(o+p)+vw/(v+w)))+x+y)((e+f)(h+i)(k+l)/(e+f+h+i+k+l)+j)/(((q+r+s+tu/(t+u)+z)(m+n+op/(o+p)+vw/(v+w))/((q+r+s+tu/(t+u)+z)+(m+n+op/(o+p)+vw/(v+w)))+x+y)+((e+f)(h+i)(k+l)/(e+f+h+i+k+l)+j))+d+g)) = 22
can't be too hard.
willem2 said:
can't be too hard.
That's a good one :)
can't be too hard.
Yes~
that's what he said to us. B to C and D to Y value should be equal to 1 over 19 since it's the reciprocal of 19. So, if A's value is 3. 19 + 3 you'll come up with 22.
1/19 = 1/? + 1/?
or
1/19 = BtoC + DtoY
Setting all resistances equal would make this a good quick exercise in series/parallel analysis. ❪It's almost obvious that that's what should be intended. :wink:
