What defines a real negative voltage?
Negative voltage is defined by the reference point used to measure it, which determines whether the voltage is considered positive or negative. In electronic systems, such as data cables, the polarity can switch depending on the configuration at either end of the cable. The concept of voltage relates to the energy associated with electrons, which carry a negative charge. Understanding the reference point is crucial for interpreting voltage levels accurately. This discussion highlights the importance of context in defining voltage polarity in electrical systems.
Taylor_1989
This has been bugging me for a long time! Now if electrons are -Q and the V is basically what energy is added to that Q how do you define the voltage as being - or +. For example in a computer system, the data cable has + and - negative voltage, so is the polarity switch at ether end on the cable?
I do apologise if this doesn't make much sense, I am not very good at explaining, what I am trying to ask.
The reference point determines whether we have a positive or negative voltage.
See this example
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 32 ·
  • · Replies 18 ·
9K
  • · Replies 20 ·
