How Does the Interface Determine Sensor Speed?
  • Thread starter Thread starter Tabaristiio
    Sensor Speed
The speed at which sensors like keyboards and cameras transmit data to the CPU is primarily determined by the rate of data acquisition, typically measured in frames per second for images and a separate data stream for sound. Key factors influencing this speed include frame rate and pixel resolution; higher resolution demands more processing power and bandwidth. The minimum frame rate for effective visual perception is around 24 frames per second. The overall quality of the output is influenced by system capabilities, including resolution and frame rate. Additionally, the term "speed" can refer to either data rate or latency, with latency being affected by the polling rate of discrete inputs and the various layers of the interface, particularly the fourth layer, which involves CPU interrupts that can introduce delays based on priority and CPU load.
Tabaristiio
What determines the speed of a sensor (keyboard and cameras) transmitting data from the external world (pictures, sound) into the processor (CPU)?
Computer science news on Phys.org
Simple answer: it is the rate of data acquisition, usually measured in frames (still pictures) per second. Sound is usually recorded in tandem with each frame in a separate data stream. The cpu on the server can combine the multiple streams into a single digital representation of the data, example: mp3 format.
Two factors determine upper limits: frame rate and number of pixels/frame - more resolution requires more horsepower on the sensor, its processor, and the data acquisition channel (wire). So it is the total data load on the system.
Questions like this are general, so the best that can be done is to give a not-perfect fuzzy general answer. Generally there is a trade-off in terms of cost: better quality video costs a lot more. The minimum frame rate has to be faster than human image formation in the eye - probably 24 frames/sec. How good the result looks depends on system quality to a large degree i.e., resolution and frame rate.
Likes 256bits and scottdave
In a word the "interface". More specifically, by "speed" you could mean either the data rate or the latency from the time that an external event happened to the time that the information is available to the CPU.
Generally speaking, discrete inputs (such as keystrokes or on/off sensors) are polled - so the polling rate needs to be considered. Next, the information is transmitted. Each layer (https://en.wikipedia.org/wiki/OSI_model) of the interface can contribute to latency. In particular, layer 4 usually requires the servicing of a CPU interrupt - and that can be delayed by the interrupt priority and CPU loading.
Likes 256bits
Thread 'ChatGPT Examples, Good and Bad'
I've been experimenting with ChatGPT. Some results are good, some very very bad. I think examples can help expose the properties of this AI. Maybe you can post some of your favorite examples and tell us what they reveal about the properties of this AI. (I had problems with copy/paste of text and formatting, so I'm posting my examples as screen shots. That is a promising start. :smile: But then I provided values V=1, R1=1, R2=2, R3=3 and asked for the value of I. At first, it said...
  • · Replies 70 ·
  • · Replies 24 ·
  • · Replies 21 ·
