What do you folks think of Arduino?
  • Thread starter Thread starter KaleLetendre
    Arduino
Arduino is recognized as a solid platform for building autonomous robots, offering numerous I/O ports suitable for robotic control. However, users encounter challenges with storage and voltage limitations. To enhance functionality, combining Arduino with Raspberry Pi is suggested, where Arduino handles low-level tasks while Raspberry Pi manages higher-level operations, creating a robust system for robotics. WiFi connectivity expands storage options, and for powering high-voltage servos, additional controllers like power transistors or SCRs are recommended. While Arduino can be cumbersome for managing multiple servos and sensors, alternatives like the Pololu Maestro Controller provide a more user-friendly solution, allowing control of up to 24 servos and compatibility with common programming languages. Despite these improvements, memory limitations remain a concern, which can be addressed with mini desktop solutions.
KaleLetendre
What do you guys think of Arduino? I have been using to build little autonomous robots and it seems to work pretty well other than storage and voltage limitations. Is there anything better i could upgrade to or should i just stick with it?
Technology news on Phys.org
Arduino is good as a robotic controller. It has a lot of I/O ports for that kind of work. The difficulty is the development and downloading of code. In order to fix that, some folks have done projects using a combination of arduino and raspberry-pi. The Pi can be programmed directly and then be connected to the arduino to send it commands.
In a sense, you'd use the arduino for low-level robotics and the Pi for higher level robotics. The two together provide a very powerful platform for robotic control applications.
http://readwrite.com/2014/04/16/arduino-raspberry-pi-connected-home-tutorials-projects/
Likes harborsparrow
Arduino and Raspberry Pi are versatile little critters, useful for much more. Even hackers use them, but I won't discuss that. WiFi connectivity brings options for storage. For powering higher voltage servos and motors you'd just use controllers that can connect to them but handle more power with power transistors or SCRs, with a separate power source for that load.
Likes harborsparrow
Arduino is not very user friendly when it comes to controlling multiple servos or reading sensors. The Pololu Maestro Controller can control up to 24 servos and be programmed in C# in Visual Studio through the USB port. Each servo/sensor has three pins on the board : positive,negative, and signal. The Arduino has it's pins all over the place. If a controller requires a unique company created IDE don't waste your time. The Maestro Controller is made for common programming languages.
This board in the link has 6 ports for servos,inputs, and outputs.
https://www.pololu.com/product/1350
Looks like the Polulu might solve the power problem but not the memory issue; the link has follow ons to GitHub to info on using Arduinos to control Polulus.
Learn If you want to write code for Python Machine learning, AI Statistics/data analysis Scientific research Web application servers Some microcontrollers JavaScript/Node JS/TypeScript Web sites Web application servers C# Games (Unity) Consumer applications (Windows) Business applications C++ Games (Unreal Engine) Operating systems, device drivers Microcontrollers/embedded systems Consumer applications (Linux) Some more tips: Do not learn C++ (or any other dialect of C) as a...
  • · Replies 51 ·
  • · Replies 38 ·
